Little help please
Arlright. Here's my issue. A week ago my car was broken into and when they stole my deck they just pulled out the entire center faceplate thing (technical term, of course.) that has the ac ***** and various other gadgets on it.
Geico does not cover anything aftermarket under my insurance even though i sent them paperwork on everything put in the car when it was purchased. Basically I got $448 dollars to fix everything.
My question is: Do you guys know of anywhere (dealer or aftermarket supplier) that sells that wiring bundle that runs from the back of the A/C controlls and the radio etc... I'd like to just replace the whole thing if at all possible, rather than paying someone my entire savings to return my i.c.e to bone stock.
I'm assuming (hoping) the wires all run back to a similar mass clip style origin point somewhere else behind the dash and i can just take out the old bundle and clip in the new one...
Sorry so long, any info would be GREATLY appreciated.
NO dont call dealer! Go to majestichonda.com, go into the parts section and click on garnish (passenger side), its the cheapest you'll find that whole setup, keep a look out on ebay too, sometimes salvage yards sell them
they are ignorant theives, pulling the plug would have taken less time than cutting it. There are a few relays and constant power wires in that cluster, did you blow tons of fuses and have electrical problems?
Here you go buddy this should do it for you,
Here is the link so you can get prices and all that. honda automotive parts linky
Damn, that is a harsh theft. I'm sure that Majestic Honda will have the parts you need to fix it though. There are a number of large plugs under the dash, if I had to guess, I would say that one of them has all the wiring for the HVAC panel, and possibly the stereo as well. You will most likely need to pull the center console out (not hard) to access them, but if I am correct, then the install should be easy. You can see them in my pic below (big blue plugs), and IIRC there are more of them that you can't see in the pic, under the dash, towards the front of the car.
