Keyless with key in ignition....
Old Oct 1, 2006
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Okay, so you probably don't care and I'm probably wasting my time but I get home this weekend and figured everything out!
If you want to be able to keep a Civic running and lock the doors, it is as simple as cutting the middle wire on the keyless entry module located in the dash under the receiver.
If you want to be able to lock the doors with the key in the ignition, well, can't really tell ya the proper way but what I did is disconnected the wiring harness for the key sensor and left it off...the problem with this is the car no longer knows when the key is inserted or removed and will not ding if the key is in.
If you want to be able to lock the key in the ignition AND lock the car with it running, you have to do both....
Old Oct 1, 2006
Rennen's Avatar
New Mod on the Block
.... my car can lock when its running...
Old Oct 1, 2006
With factory keyless entry?
Old Oct 1, 2006
v8eaterokv6's Avatar
i have a new home do u
so can mine just press the lock button on the door.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
meicalnissyen
Sep 22, 2015 06:20 PM
Klame9420
Sep 7, 2015 10:03 PM
