Quick Question (pics)
Old Sep 9, 2006
TrAvIs 05's Avatar
TrAvIs 05 is an unknown quantity at this point
Does this hole:
lead to the hole behind this carpeting (somewhere by the red circle)?
Old Sep 9, 2006
BRED civic's Avatar
BRED civic is an unknown quantity at this point
it sure does
Old Sep 9, 2006
AmbulanceMonkee's Avatar
Hard to tell exactly which hole that is because the first shot it zoomed in, but i think that one is directly behind your glove box. I used mine to run my tach wire. Take your glove box out, and gently stick a coat hanger through. See where it comes out.
Old Sep 9, 2006
TrAvIs 05's Avatar
Yeah, the first pic it seems like that hole is even with the glove box and the one in the second pic seems to be a lot lower (i was assuming it was on some sort of an angle). So, there's another one right behind the glove box? I'm going to be installing an amp so i need a hole to run the wires through.
Old Sep 9, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
The rubber grommet that is located where you have the red circle is all the way down in the engine bay, way lower than the first picture. It is kind of tricky to get to from the engine bay. Just go from the inside out, it will be easier to find and grab.
Old Sep 10, 2006
Use the higher one, from the first pic. You can run the wire down the passenger side, under the carpet and up into the space behind your glove compartment. You'll need to remove the clips for the glove box, and the piece of trim below it. Neither of which are too tough. i wouldn't mess with trying to find the lower hole, it'll be under the carpet, and harder to reach from the engine bay cause it's farther down.
SinusoidalGraph
Transmission swap
Jun 26, 2015 04:43 AM
thana
Jun 15, 2015 11:58 PM
Optimus34
May 25, 2015 11:52 PM
MooCoW
Nov 9, 2001 05:22 PM
ImmortalEX
Nov 8, 2001 09:52 PM
