radar detector hardwire - sunroof / moonroof?
Old Sep 2, 2006
alister's Avatar
alister is an unknown quantity at this point
I searched and found some good threads on hardwiring a Passport 8500 to the fuse box but is there there a simpler way to do it if you have a power moonroof? I wired our other 8500 in the Lexus behind the lighting and switch to the power roof. This was simple and short. I was just wondering if anyone had done this or even if was possible on the Civic. Thanks.
Old Sep 2, 2006
es2k2's Avatar
Proud to be a civic owner
i did it to the cigarette lighter
Old Sep 2, 2006
alister's Avatar
Trying to avoid going across the window and down the pillar but I may just take apart the switch and do so testing first.
Old Sep 10, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
You will find 12V constant signals at the sunroof motor and relays but not accessory. This is also true at the interior lights (you need to be able to turn the lights on without the car being on.) The best way to do this is to just pull the a-pillar and run your wiring across the headliner and down the pillar. I would recommend grabbing accessory at the ignition harness. Look for a black/red or a white/red.
Old Sep 10, 2006
alister's Avatar
Thank you for answering conclusively.
runawaykinms
15
Mar 22, 2019 10:32 AM
h4ldol
Apr 24, 2017 08:16 PM
SammySC
121
Apr 7, 2017 07:43 PM
JMKendrick
Sep 16, 2015 06:17 PM
EM2661
Sep 11, 2015 06:01 PM
