reverse relay
Old Sep 6, 2006
shmik1's Avatar
reverse relay
is there a relay that works in reverse, meaing when the remote is off, it is on? (hope that makes sense, otherwise I can try to elaborate)
Old Sep 6, 2006
skipbarber's Avatar
get a single pole DOUBLE throw (spdt) relay and instead of using the normally open terminal, use the normally closed terminal.
Old Sep 7, 2006
WhiteRabbit's Avatar
and the standard bosche relay is a SPDT relay, so you are set!
dont forget to tap power off ACC, or add a second relay that only provides power with the key in, or else youll get power out of that relay with the car off, too! 8\
Old Sep 9, 2006
shmik1's Avatar
thanks guys!!
h4ldol
Apr 24, 2017 08:16 PM
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
