Do I need to add a cap to my system?
Old Aug 13, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I don't want to kill my stock battery and alternator, should I add a capacitor?
I have a Rockford Fosgate P325.1 amplifier running my subwoofer at 400 watts RMS. I also have a MTX 4244 Thunder amplifier running my speakers at 180 watts RMS. And I then have a computer in my car with a 90 watt PSU, so altogether that's 670 watts altogether on my car, is that too much? I've got 4 gauge wiring running from the battery to the distribution block and then 8 gauge from the block to the amps. And I've got 10 gauge wiring running from the battery to the computer. I'm being told no, I don't need a cap, but is there anyone with uber knowledge that can tell me for sure?
I'm running everything but the amp/sub right now, I have to install it.
Old Aug 13, 2006
you never need to add one. and guess where the cap gets its power from? the alternator! lol. all it does is reduce dimming. has no bearing on electrical performance otherwise, well maybe it robs a bit more power.
Old Aug 13, 2006
DeX's Avatar
DeX
Canadian, Eh!
Doesn't it reduce stress on the battery and alternator though? I heard you can kill those components by running a high system on them.
Old Aug 13, 2006
its gonna kill it anyway. the cap won't help that one bit. the real problem is the weak alternator. the solution is to upgrade to a hi output version. adding a cap will make you think everything is okay (less dimming), but in reality you still have a small alternator and crap battery with way too much power draw from the amps. all the while the cap will also be drawing power to charge itself after being used up constantly.
Old Aug 14, 2006
DeX's Avatar
DeX
Canadian, Eh!
How much to replace those? Can I just replace the wiring between the two with lower gauge?
Old Aug 14, 2006
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
yes you can but heres something that will benefit you as well: we call it the "big-3". http://forum.sounddomain.com/forum/u...=5;t=007801;p=
Old Aug 14, 2006
there was/is a post about selling custom hi output alternator on this site. i think megahurtz would know more about it.
Old Aug 15, 2006
john06w's Avatar
john06w is an unknown quantity at this point
They say to add 1 Farad for every 1000 watts. Honestly the only thing it does is reduce the instant pull that the amplifier draws from the battery.
I bought one because it was used by a friend, $20. So, it was worth it.
Old Aug 18, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
my .2 cents! http://www.7thgencivic.com/forums/sh...d.php?t=273054
cukaracha
30
Jul 26, 2015 12:01 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
