bad alpine mp3 problem
Old Aug 6, 2006
i have an alpine 9847 for almost a year now, well recently its been having problems playing brand new mp3 discs. it starts playing fine at the beginning, but as the cd goes forward, it starts skipping more and more. by the last song, it skips every second almost. i put the cd in my computer and it plays fine. i even recorded it low speed. now also this problem happened after i installed winxp and roxio cd creater. could it be the software? but why would it hardly skip at the beginning and then get worse to the end? i need some help here cause i cant listen to music like this.
Old Aug 6, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
how do you have the cd set up? you have folders or anything on it?
Old Aug 6, 2006
Ichiban's Avatar
Ichiban is an unknown quantity at this point
Your old cd player plays mp3s fine. Anyways have you tried cleaning it. They sell cds that clean the lens.
Old Aug 6, 2006
its a cd with just mp3s no folders. i have one disc with 6 files and another with 100. it does it with both same thing. ive tried different brands, idk doesnt work. the best buy said laser is out of alignment but wtf? not even a year old. i planned on keeping this for as long as the car. if this is aftermarket quality, idk what to do. and the thing is it does not do anything when playing regular cd with wav files. perfect playing. hmm? everyone says youre not supposed to use cleaning discs in slot cd players, even the manual.
Old Aug 6, 2006
I know on some you have the option to set the mp3 or just cd mode.. you do have it set to mp3/cd mode correct?
Old Aug 6, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Hey gearbox have you tried playing mp3 CD's burned on someone else's PC? That might help eliminate the software issue.
Old Aug 6, 2006
i dont have any other computer that could make cds. and ya mine is set to mp3/cd mode. does anyone have suggestion for different software? before i had winme and winoncd 3.8 which worked great but it wont install on xp.
Old Aug 6, 2006
what are you using now? I use Nero or Roxio
Old Aug 6, 2006
roxio cd creator 6
Old Aug 6, 2006
try Nero see what happens
Old Aug 6, 2006
ay its software looks like, i tried the windows xp burner and its alot better. it only skipped a few times in minutes. so we'll see. and the funny thing is the xp burner uses roxio software.
Old Aug 6, 2006
Rudy's Avatar
Rudy is an unknown quantity at this point
Try EAC - sort of DIY, but very good at both reading and writing. Free and the best is hard to beat.
Old Aug 6, 2006
lol, yeah dont you love getto widows!
Old Aug 6, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
what kinda bitrate are the files being encoded at? sounds like a buffer issue
Old Aug 6, 2006
they are all sorts of bitrates from 128 to 192 usually. the deck plays up to 320 i believe, pretty much anything. it got much better after using windows burning but still a few skips here and there. its okay for now at least.
Old Aug 8, 2006
sheesh well i reloaded winme and all my old software from an image exact how it was before, it is doing the same thing skipping like crazy. idk what to do now. i guess im taking it in to see if they can fix it. i can't believe this would happen to an alpine and especially not even a year after i bought it. retarded.
Old Aug 8, 2006
Rudy's Avatar
Does it skip on commercially produced music CDs? It could still be the computer burner. Just because it can play the CDs back doesn't mean they are OK.
Old Aug 8, 2006
well i literally went back in time to when i was burning perfect cds. complete disk image restore and i burned the cd with old software on winme just as before. there is no way its the computer now im sure of it. everything i play the cd on is perfect, even other standalone mp3/dvd players and my computer. the alpine is able to play regular music cds, both commercial or cdr doesnt matter. its mp3 that causes the problem with skipping. any more advice? also i didnt have this problem til just two weeks ago, i've been making cds with winxp and ezcd for at least a few months without issue. so nothing on my part is changing.
Old Aug 8, 2006
maybe you could send it in to get it repaired?
Old Aug 8, 2006
Rudy's Avatar
Not really. If MP3 CDs that used to play OK don't anymore, it's probably the Alpine. The thing that stands out is that it doesn't matter if the disc is full or not. That says that the skipping isn't based on the position of the data on the disc which you would expect with an alignment error.
It almost seems like a software error on the Alpine. My Eclipse has a reset button. Do Alpines have the same thing?
Old Aug 8, 2006
yea i actually just ran out and tried the reset button. nothing. i actually even dug up an old cd that i made a year ago in the back seat and even it was skipping. so the alpine is defective. hopefully they can fix it but it worries me that something would happen so fast. i dont wanna have to worry about this all the time if out of nowhere it starts skipping again. and i love the lighting on it thats the only reason i got it. couldnt find a single deck that has all amber display and white lcd. have you? because if they cant fix it i need something else. matching is very important for me, and mp3 playback. and i treated this alpine so good. always took the face in when it was sunny, never dropped or got it wet, there are almost no scratches anywhere.
Old Aug 8, 2006
Rudy's Avatar
I'm sure it can be fixed. Wonder if it has anything to do with the battery problems you had?
Old Aug 8, 2006
well the battery just went dead, i dont think it wouldve damaged the deck, i mean the car just wouldnt start and deck didnt turn on either.
Old Aug 9, 2006
well if that alpine can handle an ipod adapter and you have an ipod. i got an interface you could plug into.. walla mp3 problem solved
Old Aug 9, 2006
that interface is way too slow it would drive me nuts. idk im pretty upset i cant listen to any music i have. lets see if they can fix.
Old Aug 9, 2006
Rufus's Avatar
PM your address and I'll mail you an MP3 cd that worked in my IVA-D900. Should work fine in yours.
Old Aug 9, 2006
well i dont think that will help me. i had cds that used to play fine but now dont. i doubt yours will be any better. i have a spare deck lying around im just gonna swap it and drop mine off at best buy for repairs.
Old Aug 9, 2006
Rufus's Avatar
There ya go. Good luck.
Old Aug 9, 2006
i dropped it off at stupid best buy, its gonna be at least 3 weeks to get it back. so i did a quick splice with an old old alpine deck. it has not even skipped once and this was the cd i pulled from the trash cause i left the new one in the broken deck.
beveragemp
May 25, 2015 07:11 PM
pantdino
15
May 13, 2015 02:22 PM
dooner24
Apr 14, 2015 07:51 PM
BumpinCivic2k1
Nov 18, 2001 04:44 PM
ImmortalEX
Nov 15, 2001 06:29 PM
