Which side of trunk should 12" sub go?
Old Jul 4, 2006
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
Soon, i'd like to make a custom sub box for one 12" sub for an 01 ex. Its going to go into the empty space on either side of the trunk. I was just wondering if one side was better than the other, so one side of the car won't be sitting lower than the other. With the 2 12's that are in the car now, and the huge box, its making the *** sag. And besides the fact that only one of the subs is working. Thanks
Old Jul 4, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
I am pretty sure it doesn't matter which side it goes on because the sag which you are conserned with would be there regardless and if you put the sub on one side id put the amp on the other to even it out but for sound it doesn't matter
Old Jul 4, 2006
tuner04civic's Avatar
spell check pwns you
either way the rear will be a little lower with the weight you add. i would do the back middle, but if you need the spare tire go either side.
Old Jul 5, 2006
phuviano's Avatar
Slowest 7thgen in the GTA
Sound wise, it doesn't matter which side you pick. I have one sub in my car, and its directly in the middle. However my driver's side rear is lower than my passenger side rear. I would put it on the passenger side just to add a little more weight to that side. I'm not the only one that has this issue with the driver's side being lower. I've read on someone else's post, and notice this is the same on my ride.
If your lowered, you'll notice your driver's side is slightly lower. If you not lowered, you may not even notice. It really doesn't matter which side you put it on though.
Old Jul 5, 2006
WhiteRabbit's Avatar
Ive noticed a significant improvement to the way my car drives on freeway on-ramps based on how the weight is distributed.
when I am the only passenger in the car, adding more weight to my own side doesnt help me on those cloverleafs!
I have also noticed the car tracks more easily when the weight sits over the wheels rather than by the tail lights.
I have never noticed any sort of advantage or disadvantage to equipment location to the way the car drives at any other time. (other than cloverleaf freeway on-ramps.)
all qualititaive, no measurement, and all unverifiable. but for what its worth, they are my uneducated observations.
Old Jul 5, 2006
Well the car is dropped on eibach sportlines with koni's, but the only thing i have noticed, is that the rear is quite a bit lower than the front, but i expected that having the huge box in the trunk and not having put the spc camber kit on yet. So it looks like i might try it on the passenger side.
Old Jul 5, 2006
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
I would say put it on the passenger side to even out the weight with the driver. Overall on the out side I have no sag at all due to the two different springs I have on the car. Here is my set up... for more pics look at my gallery...
Old Jul 5, 2006
That looks really good, which seperate springs are you running?
Old Jul 5, 2006
THE LONE STAR STATE
Tokico "blues" shocks/struts (front/rear) with Tein-S-Tech in the front (1.5"). The rear has the Tein-H-Tech springs (1"). Then with just the system (not to big of a system) the front tilts down a bit. Now if you put the passenger/system in the back it levels out, see the wheel gaps...
DerbyDad03
Exterior
May 16, 2021 10:07 AM
Adam925
Nov 19, 2019 10:56 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
Youshoe
May 22, 2015 09:36 PM
ej8
Apr 13, 2015 06:36 PM
