Wiring question/problem.
Old Jul 1, 2006
Sinisterdexter's Avatar
I Pinch.
Sinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of lightSinisterdexter is a glorious beacon of light
I am currently in the process of wiring my subs/amp. I have all the wires run but when I try to connect the 4ga to the positive terminal it arcs and is getting hot enough to melt the terminal! I have the ground run in the trunk. I'm wondering if anyone has any ideas why it is throwing that much power into it...
For reference it's a Rockford Fosgate 4ga setup with a 60amp wafer fuse.
Old Jul 1, 2006
sparks? might be a bad amp.
Old Jul 1, 2006
I Pinch.
I was thinking that too... But as a test I hooked the wire up without it being connected to the amp and it did the same thing. Without it even being hooked up to the ground(so not a complete circuit)
Old Jul 1, 2006
maybe try a test light on the power and ground wires. wear goggles and gloves. if the bulb lights up, all should be good. if it blows up, bad. something is wrong but idk what.
Old Jul 2, 2006
I Pinch.
Well... I would do that but I can't even connect the positive lead back to the battery with the amp power connected. If I do just the stock wire it's fine. The minute I attach the 4ga wire with it's terminal it starts to spark and melt the battery post. I was thinking that it may be a short in the line(since I had to pull it through the firewall hole) but I checked and it's fine. Also wouldn't a short blow the fuse?
Old Jul 2, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
where is the fues located at? before the amp or right after the battery? Just currious. sounds to me like you have a short some where in the line if its melting the post on the batter.. Idea: take amp out and hook it directly to the batter and see if it powers on.. ie 12v+ to remot and 12v in. if it arcs you probably hava a bad amp
Old Jul 2, 2006
I Pinch.
The fuse is in line from the battery to the amp. Probably around 12 inches from the battery.
I'm not sure I fully understand what you are suggesting though. Because it arc'd when I just connected the bare wire, ie not connected to the amp at all. I checked the entire length of the wire and there's no tears or anything.
Old Jul 2, 2006
wiat it arced when you didnt even have it connected to the amp? yeah something wrong in that wire.
Old Jul 2, 2006
I Pinch.
Fantastic. Like I said, I checked the entire wire and there's no splits, tears or melted parts. You'd think that by spending a few more dollars and gettign a decent name brand like Rockford Fosgate I wouldn't have a problem like this.
Old Jul 2, 2006
Do you have anything else hooked up? ie a capasitor? or alarm or sometihng?
Old Jul 2, 2006
Rudy's Avatar
Rudy is an unknown quantity at this point
Have to have a short to ground if current is flowing with just the cable connected to the wire. If it is hot enough to melt the terminal, it should be blowing the fuse. It sounds like the short must be prior to the fuse.
Test for continuity between the unconnected power wire and a grounding point. I'd take a careful look at the battery size of the fuse holder - stray strands or maybe a mounting screw in contact with the conductor.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
