Has anyone changed from a 12w3v2 to 12w3v3?
Old Jun 19, 2006
A03's Avatar
A03
A03 is an unknown quantity at this point
Just curious if anyone is running the 12w3v3 woofer and used it to replace a 12w3v2. What differences do you notice, if any?
Also, please list if you are using a sealed or ported enclosure and what sort of amplifier is driving the woofer(s).
Old Jun 22, 2006
Black02Civ's Avatar
Black02Civ is an unknown quantity at this point
I'm curious about this too. I have a 12w3v2 in a vented box with the JL 250/1 amp, and have been wondering if i should get the v3. Hopefully someone can fill us in.
Old Jun 22, 2006
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
I don't have either sub, but we got them in at the shop a couple weeks ago.
Asthetics are definately nicer. They switched from those crappy spade terminal connections to nicer spring loaded barrel connection type. All W3v3's are single voice coil now (2,4, or 8).
The magnet is larger, woofer is a little bit deeper, its definately heavier. Hooked up in our sound room, the W3v3 is noticebly louder than the W3v2. Sounds the same to me however, though I always thought the W3v2 was a great sounding woofer to begin with.
I believe the W3v3 should handle more power than the v2, we installed two 12W3v3's in a car with a 1000/1, handles the power great. The e1800D should probably be a great match for a pair of v3's.
In all honesty, its not a huge upgrade going from a v2 to a v3.
Also worth noting, the recommended enclosure size went up, I forget the actual numbers, but I think it was .5 cubic feet larger on the sealed and 1 cubic foot larger with a ported enclosre
Old Jun 23, 2006
A03's Avatar
A03
Thank you Slick. I've found most of your posts good and helpful. It's good to know that you are also working with a JL dealer. If I ever need more equipment I will check in with you.
I suppose I will keep my v2 for now.
Edited - added the below text:
Slick, where did you read that the enclosure size went up? According to www.jlaudio.com the enclosure advice stays exactly the same, except for the 4ohm v3 which lists a very slightly smaller enclosure (sealed). I believe they work well in larger enclosures, I just wanted to know what the source of information was.
Second edit -
The specific woofer & specs I am talking about is the 12w3v2 vs. 12w3v3. Sealed enclosures.
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
BootyDo
May 7, 2015 04:46 PM
andjosaus
Apr 28, 2015 10:02 PM
silverdevil
20
Jun 2, 2007 04:42 PM
htowncivicEX
Jan 21, 2002 11:48 AM
