Help installing power for the amp
I cant seem to find a place to run the power from the battery to the amp through the fire wall. any help is appreciated, thanks.
Ok, on the passenger side where their feet goes, pull the carpet back and you'll see a boot with some wires running into it up under the dash. Cut a slit next to the wires and then stick a screwdriver or something through it. Go into your engine bay and look behind the engine and feel where the screwdriver is and shove the power wire in through there.
exactly. There is arubber nipple that you can fit the wire through. If it wont go cut a tiny hole and push.
Once through there you can run it under the center console. After that take it under the carpet in the back, and under the rear seat. Thats what I did, when I re-wired all the stereo components, and its an awesome way to run the wire
Boost is so good make you wanna slap ya mamma
Or after you get the wire through the firewall you can run it along the plastic interior panels on the passenger side. Thats how I had mine go before i relocated my battery to the trunk.
Youshoe
May 22, 2015 09:36 PM
