Looking for louder than what i got
Old Mar 12, 2006
chriscivic's Avatar
chriscivic is an unknown quantity at this point
alright, i want to get as loud as possible in my civic. my current set-up is 3 12" alpine type r's in 2.25 cubes a piece tuned to 33hz. for power i have a orion 2500d. So the r's have about 850 rms to each sub. i want to get high 140's or even break a 150 on the new termlab meter. i know it is not easy to break a 150 but i want to. i am looking for new subs or a single sub to run at 1 ohm or 0.5 ohms on my 2500d. i have 1/0 power and 1/0 big three, and will possibly get a new alt. if the member on here gets the small block chevy alt kits done. let me know your thoughts on this.
Thanks,
CHris
Old Mar 12, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
Get some Kicker L7's.. I have 2 12" L7's with a HUGE *** ported box and that **** thumps, I have 2 1200 Kicker Mono Black Class d amps pushin them
Old Mar 12, 2006
chriscivic's Avatar
How big is your box and what is it tuned to?
Old Mar 13, 2006
LudlamTheory's Avatar
i boogie for the raindrops
hitting 150 in a daily driver tuned system on a new TL meter, will not be either cheap or easy
hitting 150 in an spl tuned system that would sound like *** playing music, is a different story
so I have a few questions I would like answered:
1 - daily driver music system, or pure spl one note competition system
2 - any budget constraints?
3 - coupe or sedan?
4 - how far are you willing to go install-wise (i.e. walls, removing rear seats, etc...
5 - who's doing the install, and how much experience do they have
the reason I ask, is because 150 is not easily done, regardless of how often you see it published on paper.
Old Mar 13, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
If you want to push it @ 1 ohm, make sure your amp is 1 ohm stable. At lot of amps claim to be but most of them are bullshit. So double check before you wire subs to 1 ohm.
Old Mar 13, 2006
chriscivic's Avatar
1.daily driver, tuned low
2.~400 for subs, have everything else, used equipment is fine
3.sedan
4.thinking of sealing trunk from cabin and have port/subs behind seats.keeping the 2500d.
5.me and a friend, pretty good experience, won local sound off 1st and 2nd place last year. experienced in box building.
ideas so far are sealing the trunk off with either 2 12" or 2 15" orion h2's at 0.5ohm tuned b/w 33-35hz with 3 4" aeroports or 1 6" aeroport.
believe me this amp can do it, i will be running it at 0.5 ohms
Last edited by chriscivic; Mar 13, 2006 at 09:20 PM. Reason: Automerged Doublepost
Old Mar 13, 2006
frenum101's Avatar
frenum101 has a little shameless behaviour in the past
15" kicker solo X
Old Mar 13, 2006
chriscivic's Avatar
they don't make a 15" solo x, and i don't want a solo x
Old Mar 13, 2006
frenum101's Avatar
yes they do ive seen them
Old Mar 13, 2006
chriscivic's Avatar
you have seena 15" solo x, find me a website with a 15" solo x
you didn't find one did you?
Last edited by chriscivic; Mar 13, 2006 at 10:57 PM. Reason: Automerged Doublepost
Old Mar 13, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
kicker makes an 18 inch kicker solo X. 2 would probably brake 150.
link to some on ebay.
http://cgi.ebay.com/2-18-Inch-Kicker...QQcmdZViewItem
only thing is getting them in your vic! lol
Old Mar 14, 2006
tuned in the low 30's, i doubt youll hit 150's.
just being brutally honest
now, if you still wanna do a pair of h2 15's in a quasi-wall, what you could do is have interchangable ports to have it tuned low for daily, or high for competing.
Old Mar 14, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
http://www.kicker.com/06/index-dom-high.html
10,12,18
Old Mar 14, 2006
urwhat's Avatar
urwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really nice
why not try buiding an ABC box.. (a box with basically two ports) or use lots of sound deadening and whatnot.
Old Mar 14, 2006
chriscivic's Avatar
I was looking at h2 15's b/c of their small enclosure requirement. What is a "quasi-wall"?. Do you think sealing th trunk from the cabin would be a good idea to gain spl or not? Orion recommends 2.25cf per sub, so i was thinking of sealing the trunk off and porting into the cabin, enclosure would be b/w 2.25-3 cubic feet per sub and 3 or 4 4" aeroports. i would get two dual 2 15" h2's to run at 0.5ohm for ~3000rms after electrical upgrades
also with these aeroports i would be able to change tuning pretty easy
and this set-up tuned high,is possibly a 150?
Last edited by chriscivic; Mar 14, 2006 at 09:43 PM. Reason: Automerged Doublepost
Old Mar 15, 2006
first off, your trunk including everything is 10+ cubic feet easily.
a couple guys have tried sealing off the trunk and cabin from each other for spl and haven't done too well.
is that 2.25 per sub sealed or ported?
also, whoever reccomended the dual-chamber tri-tuned enclosure has an idea that might work IF you want to get into building a more complex box design that requires a lot of exact measurements.
Old Mar 15, 2006
chriscivic's Avatar
My idea was not to actually use the trunk as the enclosure but to build a box that fires into the cabin behind the rear seats with the trunk completly sealed from the face of the box. Orion recommends 2.25 ported, And that is about all i can do b/c each sub displaces .48 cf and the port displacement will be around .5-.75 cf. DO you think the aeroports would make a significant diff, over a regular slot port?
my 2500d is on the way now, and i am pretty set on the two h2 15's for my subs. Mainly because of the small space requirments
Last edited by chriscivic; Mar 15, 2006 at 08:35 PM. Reason: Automerged Doublepost
Old Mar 15, 2006
well, that may work.
but like i said, a dctt enclosure could be exactly what youre looking for.
if you don't know what it is, it is in essence a ported box tuned at two frequencies, one low, one high.
if you're interested, I can help you design one here
Old Mar 16, 2006
chriscivic's Avatar
Kinda like a p4s snailshell? I built one for a xxx 15" , if you have seen one they have three diff. width ports. How much room would this dctt enclosure take? I am willing to try anything. I was doing 36x16x30 with the box facing foward, right now the combination of the three boxes i have is 39x16x30
Old Mar 17, 2006
man, 36 x 16 x 30 is 10 cubic feet...
you could do a hell of a lot of damage with 10 cubic feet available.
a dctt requires the same amount of room as a regular ported box.
if you will give me an evening to find my notes, i will give you exact formulas and such, but basically
two chambers, one is 2/3 of the box, one is 1/3
3 identical ports, slot or pvc are easiest, one from chamber one to front face of box, one from chamber one to chamber two, and one from chamber two to front face of box.
TheRiddicles
Sep 21, 2015 03:34 PM
MichaelLW
Sep 14, 2015 07:15 AM
BootyDo
Jul 26, 2015 10:38 AM
cloudguy
Apr 28, 2015 05:02 AM
CivicRacer5
Mar 1, 2002 09:37 AM
