semi - newbie needs help
Old Feb 21, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Ok i wired to amps to one distrubution block, and one amp is getting power and one is not..... this is the setup
from battery 12v to distributor - then to each amp . its an RF distributor
the wire is 8gauge
the ground is fine
everything is plugged in.....but these are what might be causing the problem.....
from the dist. block is a fuse thats built into the wire sorta speak, then it plugs into the amp.
from the battery to the dist. block, there is a fuse built into the wire
remote wire is fine..... i just tapped the second amp into the original remote wire
im gonna take it into the shop.....but they charge a lot. so if you have any tips help me out here
and if your gonna ask for my setup i have ........ 2 12" CV HED Subs, 2 xplod 760w 2channel amps, 2 pioneer 220w max 6x9's, pioneer premier 6.5's, pioneer premiere tweets, and then in the back i have the stock 6x9
s repositioned to give even more sound =)......one amp power 2 12"s, one amp powers 2 6x9's . the old 6x9s and fronts and tweets run off the HU= pioneer deh-p6300
Old Feb 21, 2002
VNlilMAN's Avatar
The Standard One
try switching the power wires. you know the two that go from each amp to the distribution block. this way you'll eliminate some of the causes. if the same wire still doesn't work then atleast you'll know that its not the distribution block itself.
Old Feb 21, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
try usin a volt tester while ur system is on and see if the batt connector is gettin power
if it is then try replacing the fuse on the amp
if that dont work then most likely its ur amp its fried
if the batt connector isnt gettin power
check the fuse on the distribution block
if thats not it try another power cable
and if none of that works im not sure what to tell you
its kinda hard to visulize what can be the problem sittin in my room and not having a volt meter and ur car in my drive way
Old Feb 22, 2002
trevor's Avatar
trevor is an unknown quantity at this point
I know its a dumb question but are both your power lights on your amps on???????
that could help alot.......
if one is and ones not......swithch the pwer wire.....if the one amp that wanst getting power now is then its the block,,,,,,,if not,,,problems w/ the amp[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 22, 2002
mohawkboom's Avatar
Play around with the wires.. Might be your Xplod amp is deffective..(not totally uncommon)
Cheers
Mohawk
Old Feb 22, 2002
dont worry everyone, i fixed it me self.....just needed to re-wire the remote wire, no big deal! sounds great!
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
General DIY
Sep 25, 2015 08:02 PM
pilebuck13
Sep 21, 2015 10:45 PM
Donahue
Sep 8, 2015 09:00 AM
martinsmartin
Aug 15, 2015 07:34 PM
