Head units with Main Input RCA's
Old Feb 19, 2006
john_817's Avatar
john_817 is an unknown quantity at this point
Do all head units have RCA's as main inputs? I don't think mine does. I got a Pioneer DEH-7500. It only has Front, Rear Output, and Rear RCA's. I dont see any that would be main input. I'm asking b/c i have an audiocontrol three.1 and im trying to hook it up. i thought the front rca would act as the main inputs but i tried it and it doesnt work. So if there are no main rca inputs then i'll just have to connect the inputs through the speaker wires b/c that's the other option of connection.
Old Feb 19, 2006
Supa_Fli's Avatar
Supa_Fli is an unknown quantity at this point
hey i might have read your post to quick and the wife need attention so real quick if your talking about subs you could go to and electronics store and buy whats called a cross-over box. its a little black box that has the two rca outputs you plug into your amp and it has like four wires that you splice into your rear speakers. im not sure but i think the concept is that it filters out the highs and gives the rest to the amp. radioshack use to carry them and i think you can order them off line but im not sure, i used one back in high school, no problems good stuff. hope that helps
Old Feb 20, 2006
john_817's Avatar
thanks but thats not what im talking about. i think i just need to connect this preamp into the speaker leads and i will work.
Old Feb 21, 2006
LudlamTheory's Avatar
i boogie for the raindrops
theres no reason why a three.1 would need to run BACK into your headunit.
are you using an external amplifier?
Old Feb 21, 2006
john_817's Avatar
i think i figured it out. All i need is an aux input adapter for my head unit. and that should do the job. yea i have an amp for my subs
Old Feb 21, 2006
hold up, are you trying to run the three.1 eq to equalize your speakers that are running off of deck power?
if so, sir that's not possible.
maybe youre trying to do something as is done in pro audio with running an effects loop, but in car audio that doesn't apply.
i hate to burst your bubble, but the only way that the three.1 is going to work in your system is if you have an external aftermarket amplifier on your interior speakers.
4 banger
Jun 5, 2015 01:44 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
PimpBot5000
Nov 26, 2001 07:15 PM
