capacitor wiring help
Old Feb 3, 2006
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
pleae i need to know how to hook my capacitor up? any diagrams???? please help asap
Old Feb 3, 2006
CivicHX01's Avatar
positive terminal on battery --> fuse --> capacitor (ground the neg terminal) --->amp
Old Feb 3, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
^ i concur
Old Feb 3, 2006
MegaHurtz's Avatar
power wire to cap +, cap + to amp, cap - to ground
Old Feb 5, 2006
Redlined's Avatar
Redlined is an unknown quantity at this point
Am i the only one that thinks a capacitor is just a complete waste of money? It just helps to cover up a problem you already have. If your lights are dimming its because your electrical system can't keep up with the load its being given. A cap just allows you to use more power, which just stresses your system that much more. Capacitors are just bandaids for a bigger problem
Old Feb 5, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
the right farad cap = less load on the battery and the rest of our electrical system.. Second battery for the real audio freaks but its unneccessary...maybe if u park and play ur **** too long
Old Feb 5, 2006
paradoxblue's Avatar
no. if your lights always dim u have an issue. if they only dim on real hard hits. then you dont have a big issue. jsu the amp wants to much for a splti second.
then the cap comes int o cover that and stops the alrge hits from raping your battery/alt
thus saving them. it doesnt cover it up. it sovles teh issue
now if your lights are pretty well always dimmed. then you have an issue and a simple cap wont do it
Old Feb 5, 2006
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
i have 3 batteries and 2 BatCaps
Old Feb 5, 2006
its all in the eyes of the beholder. Two days ago i put a full system in a clients car and tuned it to where it sounded great on the inside, but not outside of the car. I pull his car out and tell him to have a great day. Not even five minutes later he comes back saying his car sounds awful. Turns out he wanted it to sound awsome from the outside but didnt care how distorted and clipped it sounded while sitting in the car. go figure.
Old Feb 5, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
yeah alot of people down here are the same way, they got the gain at max, the crossover at all pass, and they have everyting at max. Then they crank their system and get out of the car and listen to every part that is rattling and thats how they judge if their system is good or not. (idiots). People like us take the time to install their cheap setup and try to set it as good as we can set it, then they not satisfied and crank everything at max
Old Feb 6, 2006
i just wish they would tell me that ahead of time, woulda saved me half an hour
Old Feb 9, 2006
urwhat's Avatar
urwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really niceurwhat is just really nice
actually a capacitor is good for sound quality, and stabilizes the electrical system in the car. that way the amps dont put a strain on your cars electrical as much. it could also eliminate those nasty alternator whines if you ahve them.
Old Feb 9, 2006
stabilizes it for a split second and then acts as another drain on the electrical system.
Old Feb 9, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
Big cap. Like the Alumapro's. I have the 15 Farad, made a world of difference. Stiffens up everything, everything will run at its peak performance because there arent any drops. Its worth the money. Ive never found the 1 Farad, etc. caps to help a whole lot. In certain situations they do, in other high power apps they dont. Just my .02
Old Feb 9, 2006
hdave's Avatar
hdave is an unknown quantity at this point
thats not correct at all. caps wont save anything unless there are magical caps that produce power now. they TAKE power and RELEASE it to the amp.
the only purpose a cap serves is to reduce dimming and NOTHING else
Old Feb 9, 2006
urwhat's Avatar
yes drain, but its a more gradual drain, instead of heavy spikes. thats the main difference when using a cap and not using one. its the spikes that kill your car and whatnot, but a slowing down of the voltage drop is much easier. its like falling off a building and going splat on the ground.. or falling off using a parachute and landing softly. what would you rather do?
Old Feb 9, 2006
dont really agree with that, but im not going to argue.
Old Feb 9, 2006
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
If you guys wanna see what bass can do to strain a car. All of you that have a vafc/safc. Turn to the numerical readout and watch you rpms drop when the sub hits. Its not that much but it does happen. Problem is now gone with two caps for bass and one for highs.
Old Feb 10, 2006
urwhat's Avatar
heres what im trying to say, having a capacitor allows the amps to draw power from a closer source. think of it as a reservoir. since its close by, and there is less resistance between the amps and the cap, than there is between the amps and the battery, the amps feed off of the cap. once the amps keep continuously draining power from the "reservoir" and the line that keeps the reservoir full is already pumping out maximum power, the vehicles system voltage starts to lower along with how full the reservoir can get.
Old Feb 10, 2006
urwhat's Avatar
try upgrading the engine grounds, theres also upgrading the power wire from battery to alternator. these upgrades are the most beneficial and will usually reduce if not eliminate the dimming. also using too small of a power wire (cheap kits are notorious for having teeny tiny power wires with huge plastic insulation ) anyways, try a good set of power and ground wires. and also make sure your ground connections are just as good as your 12v+ connections. the ground carries just as much power as the postitive lead.
Old Feb 10, 2006
that i agree with
Old Feb 10, 2006
diskreet's Avatar
Yeah you would be the only one.
I love people who just jump on the 'capacitors in cars are useless' bandwagon because they do now understand what a capacitor truly is, why it works, or how it works. If you had a second level physics class you would understand all these things about capacitors. After that you would understand how it benefits a car audio system.
I am not going to waste my time typing 5000 words telling everyone here why it works, but in a car it does help.
Old Feb 10, 2006
hdave's Avatar
im in third year and ive done quite a few electronics courses.
caps in cars arent totally usless, they are only sueful to stop the lights from dimming and as a voltage stabalizer so your voltage doesnt drop too much on hard bass hits
other than that its not needed
Old Feb 10, 2006
but they look cool
Old Feb 10, 2006
fiatdale's Avatar
Tell ya what, anyone that says you DONT need one, do this. Go spend the $100 on a decent one, install it. If you have half way decent components in your system, you WILL notice a difference, not just in lights dimming, but sound. (when I say components, some idiots might think im talking about speaker components, NO. Im talking the components that make up your entire system). $100 is not a lot of money for an improvement.
Old Feb 10, 2006
urwhat's Avatar
you dont even need to spend 100 dollars on a decent one. they are all the same really, just go by the number of farads that it produces. even the cheapest of the cheap 1farad cap still puts out 1 farad. it just depends on what looks better to you.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
