Solder 16-8 gauge wire
Old Dec 30, 2005
noooorb's Avatar
noooorb is an unknown quantity at this point
How would I go about soldering 12-8 gauge wire. My 30Watt soldering Iron works fine for 16-22 gauge, but the thicker cables it can't heat up enough. Do I need like a 100Watt soldering iron?
Old Dec 31, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
did you try paste? if that doesn't work, yeah you'd need a bigger soldering gun. it is more difficult to solder large wires cause you can't completly heat the whole wire at a time.
Old Dec 31, 2005
05reverb's Avatar
did you try paste? if that doesn't work, yeah you'd need a bigger soldering gun. it is more difficult to solder large wires cause you can't completly heat the whole wire at a time. Once u get a coating on that 8 gauge, then it's easy to get them together.
Old Dec 31, 2005
noooorb's Avatar
what kind of paste? soldering flux?
Old Dec 31, 2005
eye_see_you's Avatar
let the devil out
or you can do like factorys do .. heat up a portion of solder in something that can handle the heat and dip the wire into it
Old Dec 31, 2005
fergsonfire's Avatar
Kung-Fu Kar Kare Master
fergsonfire is an unknown quantity at this point
why are you trying to solder 8 gauge? There is really no good way to do that. Or any reason to do that either.
Old Dec 31, 2005
05reverb's Avatar
yeah soldering flux. what is it for? is it for tapping that wire off of the 8 gauge? if you just want to connect them together, put the wires together and put a clamping connecter to hold them together.
Old Dec 31, 2005
Ed's Avatar
Ed
For wire that size, wires are typically just crimped with connectors. A good crimp connection is just as good, airtight and strong.
Old Jan 1, 2006
NisAznMonk's Avatar
NisAznMonk is an unknown quantity at this point
I use a propane torch for anything bigger than 12 gauge. I've used it on 4 gauge and 2 guage plenty of times with success.
What I would do is heat up the wire in the flame and melt the solder into the wire strands. Do that for both ends. Now you put both soldered ends over the flame and it'll create the connection. Good luck!
BootyDo
Jun 21, 2016 03:45 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
werdnahall
May 17, 2015 11:37 AM
Fastfebur
Apr 22, 2015 01:37 PM
