Ignited Push Button Ignition troubleshooting
Old Dec 25, 2005
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
I just got the Ignited push button ignition, and am having some trouble. I have the non-illuminated one, so there are just 2 connectors on the switch, one for 12v power and one for the starter wire. I tap spliced into the white wire and the black/white stripe wire in the steering column, and the switch doesn't do anything, although the car still starts when I crank it. Do I have this wired up right, or is there anything you can reccommend to try to get it working? Thanks.
Old Dec 25, 2005
jwalker87's Avatar
Bodacious Member
should there be a ground wire somewhere? I know the s2000 button has the same connectors as this one, plus a ground, and almost all the other switches I have have a ground, but there's nowhere to put one, and right now it's wired up correctly according to the DIY here and the instructions that came with the button. I even looked up the circuit diagram in my Hayame's, and everything looks right.
Old Dec 26, 2005
CraigW's Avatar
What method did you use to tap in ?? Have a VOM handy ??
Old Dec 26, 2005
jwalker87's Avatar
Bodacious Member
My friend had some Scotch-Lok taps that came with a Hella kit he bought, and I used those. The wires are definitely tapped, i almost cut them in half. I'm actually leaving this morning for the week, but when I get back, I'm going to try getting the power from the 12v accessory wire and see if that works.
mr_cb7
Aug 11, 2015 09:20 PM
liamfry91
Aug 9, 2015 07:54 AM
Dani1993
Jul 24, 2015 09:02 AM
emich
Jul 20, 2015 08:42 AM
cukaracha
Jul 17, 2015 05:48 PM
