Driver's side coupe door removal - problems!
Old Dec 14, 2005
synod's Avatar
synod is an unknown quantity at this point
I have everything off of the door - the power window controls, door latch, triangular piece that fits on the tweeter (or where it would be if I had one) - and I have as far as I can tell all the clips popped, because my door panel seems to be just hanging from the top. I've rolled down my window just in case that was the problem, and it might be that the door lock (the one with the red dot that goes up and down when the door is locked/unlocked) is keeping the panel on, but it doesn't really seem to be the case, the door just seems stuck at the top. Are there any of those clips at the top of the door? I only found two, one in each of the top corners, and I assumed there were none along the window seal. Anyone else had this problem?
Old Dec 14, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
the panel sits on the ledge of the door skin, did you try lifting up and towards you?
Old Dec 14, 2005
synod's Avatar
well I can't pull it up AND towards me because the little piece that goes up/down when you unlock/lock your door keeps me from pulling it towards me until I pull it up completely away from that piece - which is what it won't do. It will go up about an inch, then stop. Does that piece come off with the door panel, because it seems to move separately?
Old Dec 14, 2005
LiKEaFeRiO's Avatar
You should be able to remove it from what you are describing.
You did remove all the screws too right?
Roll down the windows and try it again...there shouldn't be anything at all that's holding the door in.
Old Dec 14, 2005
MegaHurtz's Avatar
You made no mention of removing any of the screws in the door panel, there are 2 under where thepower window controls are
Old Dec 15, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
I believe there is another screw or 2 behind the plastic piece behind the door handle. Its a rectangular piece you have to take off. Behind that rectangular piece, there's at least one screw if I can remember.
Old Dec 15, 2005
also, did you detach the door release rod?
Old Dec 15, 2005
synod's Avatar
screws are all removed - handle is detached from rod/removed - what's this "door release rod" you speak of genloch?
Old Dec 15, 2005
synod's Avatar
never mind - found the problem.
I had to pull up a LOT harder than I expected, but this due to the fact that there is a small clip in my '04 coupe that is behind the door lock (up/down deal), I could only move it up an inch, and then I SHOULD have pressed on the door panel where the clip is, on the part that I could see now that had previously been behind that little door lock. Instead I just pulled up hard and it gave, :-)
Old Dec 15, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
doing stuff like that always makes ME nervous because you never know if you're gonna break something....
Poopies
Apr 20, 2017 11:36 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MamaBear2015
May 3, 2015 02:17 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
leon1
Apr 28, 2015 07:32 PM
