battery or HO alt?
Old Dec 12, 2005
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
battery or HO alt?
i have an 03 civic and im running a true 1000rms in with all factory equipment. however, i did upgrade my grounding wires and in process of finishing the big-3. (just need to do positive alt to positive batt)
im on a tight budget and i have 2 choices:
a) buy a under the hood battery that will be ideal for my system needs (optima yellow top?...and i can get it right now)
or
b) save up more and get an HO alt (but i will have to stick with the factory battery for few months if i go this route)
my expections from this is to reduce or eliminate the strain my vehicle is getting from my stereo, reduce dimming, reduce voltage drops, and be able to drive the car perfectly safe without worrying about my alt or battery dying.
not that im blaring my system everyday i drive, my cruising volume is 50%. but their are times where i park the car and show it off to buddies and bring it to my BBQ's for music
i was also thinking about a small .5 farad cap for those high bass peaks...are those just gimmicks or actually help reduce voltage drops/dimming?
Old Dec 12, 2005
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Save up and get the alternator. It's the heart of your power supply. Then you could get an auxilary battery.
Old Dec 12, 2005
MegaHurtz's Avatar
Get the battery first.
Old Dec 12, 2005
megahurtz, i know you're big on car audio, but i want to ask you why do you suggest battery first?
Old Dec 12, 2005
fallout's Avatar
Yeah, i was also wondering the same thing. I thought that 2 batteries can stress out the alternator, and risking the chance of it dying on you?
Old Dec 12, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
when i had this problem (battery always dying), i thought it was the alternator. so i replaced it with a 140 amp. it did nothing! the only thing that solved the dimming of the lights and battery always dying was when i bought an optima yellow top. after that i had no issues. good luck.
Old Dec 12, 2005
hondapower05's Avatar
hondapower05 is an unknown quantity at this point
Your best bet with 1000rms is to get a 1 fared capaciter for now it will help the most on a tight buget. I do custom sound systems for a living so be assured that I know what I am talking about. After that then you need a Yellowtop and you will be fine. A high output alternater is only needed if you also are running alot of mods and system.
Old Dec 12, 2005
HondaSales's Avatar
i see no need for a cap with that little power
Old Dec 12, 2005
04civicdx's Avatar
04civicdx is an unknown quantity at this point
get the batt and just run it in line with your stock batt like put the optuma in the trunk and leav the stck batt up front my buddy had 3 batt in his car 3 L7 and 2 1200x1 asmp and it worked for him
Old Dec 12, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you would still need an isolator for the second battery. The only thing that a second battery is good for is to use while playing your system with the engine turned off. That way you can disconnect the starting battery from your electrical system with an isolator and not having to worry about having enough power to start the car.
Old Dec 13, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
LOL... A cap usually puts more strain on your electrical system. Reason for that is because it puts another load onto the electrical system in your car.
I don't think a cap would help out in this situation. A cap is used to provide enough power to your amplifier when needed. Its not used to save your charging system in your car.
I think a cap would probably make your bass sound cleaner. I have cap in my car and I'm only running 250RMS, but I think it makes the bass sound cleaner imo. Bass hits harder and faster with a cap.
Old Dec 13, 2005
MegaHurtz's Avatar
I thought about it and I can't remember what my reasoning for going for a batt first over an alt was, but I know at one point I had a reason. I stick by my suggestion though.
Old Dec 13, 2005
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
i have an amp that puts out 983 rms at 1ohm.. 4ga power wire..
i had it tested at 147.2 db .. but thats not the point..
i got an optima yellow top under my hood , new stock alternator and i dont notice any problems...
no headlight dimming ..
i have an 01 ex 2dr .. 70 amp stock alternator..
ive been thinkin about one of those 150 amp alternators.. seen a few on ebay and good feedback... if i ever get the extra cash ill buy one.. but im fine for right now..
btw if anyone happens to have one of those alternators ( from ebay or somewhere else ... they work pretty good? im thinkin about one but i dont wanna do it if it dont do much more than charge an insane amount back to the battery )
Old Dec 13, 2005
MegaHurtz's Avatar
FYI, I am working on getting a line of HO alts produced for our cars. When they come out they will probably be among the best on the market, I might be able to swing deals for forum members.
Old Dec 13, 2005
o really, any specs?
Old Dec 13, 2005
MegaHurtz's Avatar
not yet, I'm going to have to make my car a donor vehicle for the guy to look at for a day and we will see how feasible it is to make alts for these cars, maybe we can make a GM small case fit or something.
Old Dec 13, 2005
^keep us updated...id be interested in an 170amp HO alt if i can find one for $250.
Old Dec 13, 2005
MegaHurtz's Avatar
dont count on that kind of a price, these will be premium units and they wont be cheap
Old Dec 13, 2005
made in the good ol' usa right?
Old Dec 13, 2005
Bad_Civc's Avatar
lol id love to have a ho alternator... ive seen em on ebay but i never bought one..
the space where the alternator fits is decently sized for a bigger alternator but the problem is gettin it there.. it took like 3 hours for me to change my alternator ... plus a couple scratched knuckles
robjcivic
Mar 12, 2017 12:10 PM
haloway13
Nov 6, 2015 10:43 AM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
msaeger
Sep 2, 2015 08:47 AM
