Help with 12v socket
im stock now! T.T
ok, I have the optional ashtray lighter set which uses stock harness for the accessory power outlet. For some reason today, I was charging my phone then later pulled the charger cord out and stuck back in the lighter then I hear one small static sound and my profec dies. It does not power on anymore and nor does the power outlet work.. Is it possible to buy this harness?? without buying the whole harness? I would buy another ashtray set but it doesnt include that wire so whats the point.
Could it be possible that I blown a fuse?
I wired profec's ground and power to the accessory power harness which has power and ground, what could be wrong here. I just hope it didnt kill my profec due to this..
Someone please help me
First check the fuse if thats good then you might have fired the harness or it could just be a simply open somewhere in the circuit. Try to visually inspect the harness for any exposed wires.
h4ldol
Apr 24, 2017 08:16 PM
msaeger
Sep 2, 2015 08:47 AM
