I need HELP. I fried my deck/screen!!
Old Oct 24, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Oh man so this weekend sucked.
To make a long story, short...
I was on my way to Venice Beach and decided to plug in my friends digital camera to the Video2 of my in dash screen. i pulled over at McDs and plugged in the A/V cord - stupidly while my car was on.
everything was fine...but i could only hear sound coming from 1 side...so i switched the plug it was in and then the sound only came from the other side.
i decided i would rather have the sound on my side so i switched the cable back to where i originally had it - the speakers buzzed for about 1 or 2 seconds then my screen turned off and my deck powered down.
when the deck turned off it wasn't like power was just cut..it went to the "off screen" (or whatever its called) where it says JVC then goes back to the original angle (4 angle settings, goes back to 1, or normal when off) and then it shuts off
now, either the screen or the deck wont work - but what IS wierd is that when i hit eject on the deck the deck powers on and the face opens and ejects the cd...then when i take out a cd or put one in...it will close up again and not turn on.
the amps get power when i hit the eject button - but other than that they don't get any power. the screen doesnt turn on at all either.
i am getting a very small bit of noise from the speakers..like a maybe road noise or something..
anyways...what do i do?!??! (besides going after the warrenty...i bought from www.etronics.com and im not sure JVC will honor a warrenty...i will try if theres no other solution, though..)
Old Oct 24, 2005
skipbarber's Avatar
did you check your fuses? sounds like it isnt getting ignition. its a long shot, but worth a try.
Old Oct 24, 2005
u mean in the back of the deck? ....wait...are there fuses on the deck?...man i suck at this. lol
i checked the fuses going to the amps - didn't really know if that would have anything to do with it.
would plugging A/V cords blow a fuse though?? i mean..this was my logic. you can plug in..say a ps2/xbox, to the back of a TV while its on with RCA cords...so i figured it would be ok since it was the same type of cord..ya know?
Old Oct 24, 2005
also....what about the screen not getting power at all??
Old Oct 24, 2005
Old Oct 24, 2005
skipbarber's Avatar
if it werent getting power at all, it wouldnt eject. The amp fuses have nothing to do with the radio not working. Check the car fuses under the hood and under the dash and behind the radio if there is one. Maybe you grounded something out while plugging/unplugging the RCA's. Also, if you have a reset button, try resetting the unit.
Old Oct 25, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
possibly your switched wired is grounding out??
Old Oct 25, 2005
well..whats not getting power at all is my in dash screen. the deck gets power when i hit eject. I checked all fuses except under the dash - which one am i looking for? the fuse behind the deck is fine. you say i might have grounded something out...like...permanently fvcked up? or i grounded it out meaning its touching ground and can be moved/fixed? where would a reset button be? i don't think i saw anything but maybe its like a pin hole button or something...
um..huh??
anybody else have any info??
Old Oct 25, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Check the inline fuses behind the deck. There may be one on the yellow wire, and possibly on the red wire. Check to see if there is a fuse in the back of your deck as well. Pull the fuse panel inside and check the radio fuse there, and check your fuses under your hood.
Old Oct 25, 2005
inline fuses? yellow, red wire....can you explain?
Old Oct 25, 2005
Some decks have a fuse inline behind them in the deck's harness. Mine are fused on both the red and yellow wires on the deck I have. It's an older deck, but the prectice is still in place on some decks. Pull the deck adn look at the wiring harness. If there's a plastic cover on there, open it and check the tube fuse in there. It could be one of those that are blown. I've never even thought about a JVCrap deck, so I don't know their practices.
Old Oct 25, 2005
yeah...jvcrap...exactly what i thought when i was in the market for a deck a while back..
i had a thread about it...but i was told this deck was an exception and that it was pretty good. not only that..its the only one that would give me some sort of display on my in dash screen. i keep spending an *** load of money and everything keeps shittin out
Old Oct 25, 2005
man im dumb - trippin over a blown fuse...lol
anyways..it was the fuse under the dash dont know why that was so hard for me...lol
Old Oct 26, 2005
skipbarber's Avatar
what did i say? thats right, im your daddy. rep me.
Old Oct 26, 2005
lol well color me embarrassed
+1!
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
frank_kleng
Sep 29, 2015 10:55 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
