Q-form kickpanels installed
Old Oct 23, 2005
MegaHurtz's Avatar
Yeah I spent a bit (a lot) of time today doing this... took out the speakers that came in the kicks I bought, replaced them with mine and spent a ton of time properly mounting them and neatly wiring them. I'm not too sure what I think yet, after a good listening session or two I will be able to give an opinion. Just too bad I can't switch back and forth between having them in the doors to see what difference it makes. Still need to screw them both down somehow and find some grills that will fit, but that'll get done soon. For now, here's some pics of what it looks like. Color difference isn't that bad in real life, but it isn't perfect either.
Old Oct 23, 2005
leviathan18's Avatar
leviathan18 is an unknown quantity at this point
sweet dude one question this kick panels gives you more mounting deepth???? cuz i want kicker or rockford components 6 1/2" but all the sites says they wont fit in the front door
Old Oct 23, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
they'll fit, just gotta get spacers or make your own
Old Oct 23, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Are the colors of the panels that different or it is the camera? I was going to get them, but not if they are that far off.
Old Oct 24, 2005
MegaHurtz's Avatar
in real life there is barely any difference at all
Old Oct 24, 2005
82801BA's Avatar
82801BA is an unknown quantity at this point
Not if you get a KI ivory color, that you can really tell the difference of it depends on your car's year. I think 03-05 models in ivory are a little darker....
Old Oct 24, 2005
ramcosca's Avatar
Words on a User Title
Don't you feel like it bothers when you shift?
Or you have an auto?
[EDIT]
Yeah, auto, sorry.
Old Oct 25, 2005
82801BA's Avatar
Even for driving a manual doesn't feel bothersome....I have it in my car and mine is manual....
Old Oct 25, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
You're real liberal with the silicone eh? Looks pretty good. Hows your imaging now as opposed to in the doors? And did you consider glassing the backs of them and making them a sealed kick?
Old Oct 25, 2005
82801BA's Avatar
Megahertz's driver must be an oversized 6.5", otherwise I don't think he will mount it in from the back. Am I right?
BTW, the driver looks like the one Alpine is (and was) using for Type-X (Vifa's multi-roll sorround). Are they having the same drivers?
Old Oct 25, 2005
MegaHurtz's Avatar
Hot glue Very easy to work with and if I ever want the tweeters out I just have to give them a good push from the back. Only downside is that it doesn't exactly do a kickass job of holding the tweeter in, but it shouldn't move anyway. I solved that problem by putting on more glue, so no biggy. As of this posting, I can't get the imaging right. I haven't yet discovered a way to force my Eclipse to do manual time alignment, and there is no combination of settings yet that I have come up with that will give me an image that I am happy with. If I set it to what it was at previously, the center is too far right, if I disable TA altogether, it's too far left. There are a few wierd things that I've noticed that I am sure I will work out over time, but when I typed them out here they sounded wierd so I'll just leave that part out for now. The stage appears to have gone down a wee bit as well, but maybe that's just me. I remember it being about tweeter/sail panel level before, just a bit lower now.
I am still considering turning them into sealed kicks, I don't think it will happen right away, I might look into it over the winter. I've never glassed before so I will have to try and figure something out, but it is definitely an idea in the back of my head.
The kicks are designed for a 5.25" speaker. I didn't think that the woofer would have fit in from the front so I don't even think I tried, but looking at the pics, maybe they will. But even then, I like having them recess mounted, keeps them safer. I think they will have to be rear mounted anyway when I get my 5.25" grills in there and try to stick em on. But oh well, when they arrive I will see what I can come up with.
Old Oct 25, 2005
82801BA's Avatar
I am using Q-form also and.....It's just like what you have said....I can't even find the "center" when i listen.....It's kind of like, if I turn on TA and the sound is pretty much on the right side, and if I turn TA off and my two speakers spreads to left and right.....I can hear reflection right at my left ear(kind of like having another tweeter and upper mid pointing to my left ear) when the singer sings at the right side....
BTW, I can find the center, I just cannot get it where I want it to be and have everything else even across the stage.
Old Oct 25, 2005
MegaHurtz's Avatar
I am starting to think that it might have been a good idea to keep the speakers in the doors, but I won't come to that conclusion until I do a bit more messing around.
Old Oct 25, 2005
82801BA's Avatar
I don't think so......With the speaker at that size, you can't bring the speaker to the surface of the door panel....Then take a look at your door pocket, and the depth of your pocket will be about the depth of the speaker if it is sitting ON the metal panel. It doesn't matter, still, but if you try to bring the speaker up to the front, you have to build spacer and cut off the ring on the plastic. Then you have to get the exact depth, width, etc. to get the speaker up to near the opening. If not, your speaker will sit inside the door, and sound wave will travel in a straight line from the center of the "virtual grill" and it won't ratiate to you in any way. The reason is that, the front of the pocket (from your driving position) creates a hard surface and it will reflect the wave to the FRONT, means not your leg, but toward the pedals...
Old Oct 25, 2005
82801BA's Avatar
If you don't know what I am talking about, I will send you a picture of my front left door. I cut a hole in there to house the Dyn MW160 woofer.
Old Oct 25, 2005
MegaHurtz's Avatar
I meant imaging/staging wise it might be better to keep them in the doors (my current opinion anyway). Tonality seems to be a smidgen better in the kicks, I would only assume that is due to the lack of grills/obstacles.
Old Oct 25, 2005
82801BA's Avatar
When I have midrage and tweeter only playing 900Hz+ in the kick, the sound is right side louder. Switch the polarity of left side tweeter will be left side loud. Switch the pass side tweeter (drv side intact) the whole thing pulls to the right. Switch both midrange makes the midrange loud.....I have no idea....
Old Oct 26, 2005
ramcosca's Avatar
Thanks for the info.
So, what is the purpose of this, exactly?
And... if you move your speakers downwards, what do you do with the stock speaker hole? Leave the speakers there?
Old Oct 26, 2005
82801BA's Avatar
Either cover it by something or leave the speaker there.....
I am wondering how leaky is the factory door is.....If you have a "good" speaker there, you can actually hear the vibration of the cone blowing by the wind outside....
Old Oct 26, 2005
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
Just wondering, did you buy those kicks off of Derek-CEO?
Old Oct 27, 2005
MegaHurtz's Avatar
negatory, they came from another member of the site
what is with all these people who have kicks for sale now? I was trying to find a set for the longest time and now that I found this one, now derek has a set and so does some random guy that bought something off me on ebay who just mentioned it in passing.
Old Oct 27, 2005
AlpineCivic's Avatar
Get something with Time correction to help with the imaging.
Old Oct 27, 2005
82801BA's Avatar
I do actives for my 3-way with high and mid in Q-form, woofer in door. The only way TA works is to delay ONLY the WOOFER of the door ALONE and play with phase relative to the mid AND tweeter. TA result for the door is around 1.1-1.5ms range. Also lowering 250Hz with a few dB and widest Q on each side helps. Also need to lower the level on the passenger side woofer by 2dB or something. I don't recall that...
Old Oct 27, 2005
MegaHurtz's Avatar
already have
Old Oct 27, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
looks good i might get em i wanna add some more speakers in my car
Old Oct 28, 2005
stupidd's Avatar
stupidd is on a distinguished road
Can you purchase these online? Where at?
Old Oct 28, 2005
diskreet's Avatar
nice touch with the Xtreme
Old Oct 29, 2005
spoonEM's Avatar
omgwtfbbq mod.
i like.
Old Oct 30, 2005
yes you can buy it online @ car domain and crutchfield
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
