Tough one, see if you know the answer
Old Sep 29, 2005
Cube's Avatar
Cube is an unknown quantity at this point
OK I got a problem with my 05 Civic EX SE. I installed a plug and play Sirius receiver, it’s one that suction cups to the windshield and plugs in to the cig lighter. Now to the problem, as you know the SE comes with a 6 disc changer and has an AUX port on the front of the radio. When I use the aux cable into the radio from the Sirius unit I am getting alternator noise, when I remove the aux cable the noise goes away. I know for a fact this alt noise is coming from the cig lighter, through the unit, down the aux cable and into the radio but what steps should I take to stop it? Thanks for your time.
Old Sep 29, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
hardwire the unit in. cut the cig lighter plug off and wire it directly to a power source and make a very clean ground.
Old Sep 29, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Dammit Nick! U beat me to it!!!!
Just like he ^ said. cut off the plug and put the power(red I'm assuming) to the yellow wire on ur harness and the ground(brown/blk) to the black wire on the harness. Its that easy.
Does it have the wireless FM modulator or r u going to harwire that as well? The wireless one's kina suck IMO cuz sometimes they pick up stray signals
Old Sep 29, 2005
MegaHurtz's Avatar
As he said it plugs in via aux
Old Sep 29, 2005
Cube's Avatar
Let me add that it is hard wired behind the cig lighter, so basically it still is using the cig lighter for power and ground. I will take it apart sometime and try to get a better ground. I figured a better ground wound't hurt. Also I DO have a fuse on this bad boy! Thank you guys very much for your reply's.
One more question, I saw a DIY entry for a Grounding Kit install. Would this help me at all? http://www.7thgencivic.com/forums/sh...d.php?t=155307
Old Sep 29, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
it could be static interference from the aux wire itself
Old Sep 29, 2005
Cube's Avatar
That is not it. I have a home kit for this radio, I ran an extension cord from the shed and powered the unit up with it. I then cranked my car to see if I was still getting the alt noise. None, nada, zero zilch. Then I plugged the hard wired power cable back in and the noise reappeared. I have it nailed down, now I just have to find a better grounding location for my unit. Thanks
Old Sep 29, 2005
MegaHurtz's Avatar
wires dont interfere with themselves anyway
Old Sep 30, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you can also get an inline noise filter for the power wire since it consumes such a small amount of current. I'd bet getting a better ground will fix your problem, but if it doesnt the noise filter should.
Old Sep 30, 2005
nick95673's Avatar
just make sure you sand down the ground
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Islesfan
Sep 29, 2015 03:42 AM
sccarally
Texas
Sep 27, 2015 03:33 PM
Jrosa
Sep 14, 2015 08:24 PM
Bikergofast
Sep 12, 2015 01:36 PM
