12V power outlet
Old Sep 6, 2005
dalaw's Avatar
Bone Stock!
12V power outlet
Can you guys check to see if the inside of your power outlet look the same as mine? I suspect that black thing is a foreign object in the socket. Otherwise, I have probably damaged some wires in the back
Well a while ago, I plugged in this LED light that power off the outlet on top of the cupholder. Well as I pull out the light, the piece at the end of the plug broke off and got stuck inside the hole. It took me a while to take that **** out. I had to use a soldering gun to melt that piece and i finally got it out today. But now the outlet doesnt work anymore! So yeah I am thinking the soldering gun probably damaged some wires behind it.
ID:	59541   Click image for larger version
Old Sep 7, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
maybe the soldering iron heated up the metal and the solder in the back of the outlet and the wire for the outlet detatched.
Old Sep 7, 2005
MegaHurtz's Avatar
did you try taking the outlet apart and I dunno, actually try to remove the piece?
Old Sep 8, 2005
dalaw's Avatar
Bone Stock!
Alright I checked the cigarette lighter fuse and found that it was blown, I have to go out and buy a fuse tmrw. Thanks for the replies guys!
Old Sep 8, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
when you were in there with the soldering gun, you probably shorted the terminals together and popped the fuse. Should be fine once you put a new fuse in
Old Sep 8, 2005
diskreet's Avatar
yeah check the fuse. then check the wires behind it. if not the fuse a wire could have broken off from the iron.
Old Sep 8, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
or the wires could have simply came off the back. THey don't hold on to tight... I hate that.
Old Sep 8, 2005
well there is a plug holding the wires to the terminals. It shouldn't just come off.
Old Sep 8, 2005
ragingSPAM's Avatar
I just burnt my tongue
u prolly sent too many amps back into the wires with the soldering iron so it blew a fuse instead of letting the magic smoke out of the wires...if u let the magic smoke out of the wires u would definitly know for sure because is stinks like ****
Old Sep 8, 2005
MegaHurtz's Avatar
current doesnt come out of a soldering iron
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
sch2cm
Jul 21, 2015 09:58 PM
breanna_17
Jul 21, 2015 04:01 PM
Theshwartz35
Jul 17, 2015 11:13 PM
