double DIN in dash. Possible?
Old Aug 27, 2005
blangblizzel's Avatar
blangblizzel is an unknown quantity at this point
Cool double DIN in dash. Possible?
I know that the factory opening in the dash of my 01 civic isn't quite double DIN. However, I have a Sony XAV-7W Media center and am wishing to install a Pioneer DEQ-7600 equalizer. I have found a place online claiming they have a dash kit that will enable double DIN mounting using the factory opening. It doesn't seem possible. Any thoughts? Has anybody done it. Will it require expensive dash modification? Thanks for the help.
Old Aug 27, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
...do you mean like this? http://cgi.ebay.com/ebaymotors/01-05...spagenameZWD1V
Old Aug 27, 2005
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
check out this thread:
http://www.7thgencivic.com/forums/sh...d.php?t=189642
or check out this site:
Click me ; )
looks like a possibility.
Old Aug 27, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
That kit needs to be modified to fit.
Old Aug 28, 2005
FuzzBeC00L's Avatar
Fuzzy Boy
That's a nice kit
Old Aug 28, 2005
MegaHurtz's Avatar
that kit doesn't need to be modified to fit. I have one in my car and it works fine. I have my head unit on the bottom and a DVD player on top. the opening is a double din size.
Old Aug 28, 2005
ncoliva's Avatar
ncoliva is an unknown quantity at this point
crutchfield.com ... gives you everything you need
Old Aug 28, 2005
IS your did din size??:? i have indash tv on the top and deck at the bottom. and it won't i had to do lot of cutting.
Old Aug 28, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
i have o the double din kit... no modded needed to be done radio on bottom screen on top
Old Aug 28, 2005
Let see some pics then.
Old Aug 28, 2005
MegaHurtz's Avatar
yes they are both din. I will admit it wasn't a perfect fit, I had to cut out that middle bar and I think I had to file down the bottom of the opening so that my deck could swing open, and it was quite a bit of work to make it work properly, but it can be done, regardless.
Old Sep 1, 2005
Yeah thats it. Anybody have pics with two dins? Just got back power from the hurricane. I'm in Mobile, AL.
Old Sep 2, 2005
MegaHurtz's Avatar
^^ here you go:
Old Sep 2, 2005
matt86's Avatar
matt86 is an unknown quantity at this point
Check out LayInLow's DIY on installing a kit like that.. I followed it and its really easy
http://www.7thgencivic.com/forums/sh...d.php?t=216116
Old Sep 3, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I did a flip-flop DIY about 2 years ago on here. Looks like he took my words and added pictures, rewording a few parts. Regardless, it works, as I did that in my civic when I still had it.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
Cam Diaz
Sep 28, 2015 08:34 PM
carid
Sep 28, 2015 10:13 AM
