quick question
Old Aug 22, 2005
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
quick question
i was wondereing if inverting the subs in your box makes a difference in sound. i have some powerful subs but the have a really nice basket.i wanted to show the rear of the speaker. also i wanted to know if a ported or sealed box is better for 1500 watts and up?this will help me in making my trunk setup this weekend. thanks in advance
Old Aug 22, 2005
MegaHurtz's Avatar
might make a bit of a difference in sound beucase it will change your box volume but it won't be much. if you invert your subs, switch the + and - wiring on your woofers.
Old Aug 22, 2005
D-Vus CIV's Avatar
so ild have to get sealed.
Old Aug 22, 2005
SLO REX's Avatar
250+ awhp Stage 2
Why would you swtich the + and - wires???
Old Aug 22, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
ported boxes are loud, but sound "loose" and not as sharp. Sealed boxes are not quite as loud but it is much tighter and sharper sounding.
A buddy of mine has two of the new 12 inch type subs and he had them in a sealed box and then he built a ported one and personally i think he should have kept the sealed. It just sounds like cheap loud subs, or sloppy.
Old Aug 22, 2005
D-Vus CIV's Avatar
im wanting to runn true 1200 watts to each sub and them to be inverted but why would i need to switch the pos and neg
Old Aug 22, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
You need to switch the + And - when you mount your sub magnet out Because it makes the sub move the other way. But some HU's have a feature to reverse the sub polarity so it could be done through the HU instead (my last 3 pioneers had that feature, I don't know about other brands).
Old Aug 22, 2005
jb1004's Avatar
jb1004 will become famous soon enoughjb1004 will become famous soon enough
^ Eclipse head units also have that feature.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
