Accessory wire underhood?
Old Aug 16, 2005
gshady's Avatar
gshady is an unknown quantity at this point
Hey all. I'm trying to find out if there is an accessory wire/connection under our hood that is only hot when the car is on? I'm trying to avoid running a wire inside to the ignition to power a relay if I don't have to. I have a 2004 coupe lx if that helps at all. I couldn't find anything searching the forums so I hope this isn't addressed anywhere else. Thanks.
Old Aug 16, 2005
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
You could always just splice into the cig. plug.
Old Aug 16, 2005
MegaHurtz's Avatar
what are you trying to do?
Old Aug 16, 2005
gshady's Avatar
cig plug? As in the cigarette lighter plug? Thats a good idea but it's still inside the cab. I was looking for something under the hood so I don't have to go into the cab. It's not like it's hard to run a wire inside or anything, I'm just trying to run as little wire as possible.
Old Aug 16, 2005
ragingSPAM's Avatar
I just burnt my tongue
just connect it to the battery...lol...i do beleive there is no accessorie connection under the hood except the headlights/parking lights and fog lights if u have them...but those are connected to ur headlight switch...u can try splicing into something in the fuse box...like twisting a wire around a fuse leg and sticking it back in...thats what i did for one of my toys...i call it a booty call but its a secret
Old Aug 16, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Yea that means the cigatette lighter. Or u could use the blue wire in the wireing harness for the CD player or if you can find it anywhere else in the car. And what r u using it for?
Old Aug 16, 2005
gshady's Avatar
I've mounted a peltier in the stock air box with a heatsink on the inside to cool the incoming air down and a heatsink on the outside to cool the hot side down. Everywhere that I've read said it would not work or that it could not be done so of course I HAD to do it.
I'll post some pics of it if anyone is interested in seeing it. Its basically the stock airbox modified with the short end of an AEM intake mounted to the open end. The peltier is mounted so the air must pass it while entering the box. The peltier isn't strong enough to cool the air enough but as an experiment I would say its been a success. The air box at idle does get cold but after driving for 30 minutes the box is warm. Its not hot as usuall but its not cold.
The main thing I was worried about was condensation so I put foam around the area that the peltier sits to catch any liquid as well as put a drain hole in the inlet. Once I get the system to turn on when the car does and I'm sure condensation is not an issue I'll most likely add another peltier to increase the cooling.
Old Aug 16, 2005
ragingSPAM's Avatar
hmmm good idea..post some pix...sounds rather "cool" lol
Old Aug 16, 2005
MegaHurtz's Avatar
well, poke around in your fusebox and see what you cna find
Old Aug 16, 2005
gshady's Avatar
yeah I did that a little bit. I just gave up and thought I'd take the lazy route and ask anyone if they knew of anything.
Old Aug 16, 2005
Kyle23's Avatar
I wanna see come picks. IT sounds like a pretty decent idea. Do a DIY maybe
Old Aug 16, 2005
gshady's Avatar
Heheh.. Don't you mean SOME pics? Its most definitely a DIY if your after what you say your after.
Seriously though, I'll post pics later tonight as I don't have a camera at work.
Roman Rembacz
Jul 16, 2015 12:30 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
