Soldering help [not a typical application]
Old Aug 8, 2005
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
Hey, people. I was stringing a guitar when I screwed up [I'm a n00b] and managed to wear away the end of one string enough so that it snapped. Anyways, the string is perfect, still, I just don't have enough of that extension at the end to wrap around the tuning peg.
My question is, if I solder another extension to the end of this string, will the soldered pieces hold together under extremely high tension? Also, will the chemical properties cause any problems?
The strings are very very thin, and are made of phosphate. Thanks for the help.
Old Aug 8, 2005
CraigW's Avatar
There is a good chance the solder will not adhere to the material. If you have a scrap section you could try it to see.
Old Aug 8, 2005
TeLLy's Avatar
Yes, it's an Acura EL
The solder won't hold the string together under the tension required to keep it at pitch. Your best bet is a new string, many music stores sell individual strings.
Old Aug 8, 2005
MegaHurtz's Avatar
just buy a new string mang, it wont be the same
Old Aug 8, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
the solder will break under that amount of tension
Old Aug 8, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
wont work and if it did would sound horrible... buy a new string
Old Aug 9, 2005
It wouldn't sound different because the broken part was just the very end, which is thinner than the actual string, anyways.
These are brand new strings, and I didn't really have the time to get another single one of the same kinda, but I guess I have no choice now.
Thanks.
Mc7602
Sep 17, 2015 02:01 PM
shaejb15
Sep 3, 2015 01:35 PM
mac25
Aug 21, 2015 11:14 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
