alarm question
Old Jul 26, 2005
alarm question
Is there a way to make the parking lights NOT flash when you arm/disarm the car? I think it looks silly and would rather just hear the beep noise. I have viper 600 alarm. Any easy way to do this>?>
Old Jul 26, 2005
skipbarber's Avatar
2 ways, you can program it...or follow the solid white wire coming from the alarm and pull out the inline red fuse.
Old Jul 26, 2005
thank i'll look for it. And you mean the alarm brain right?
Old Jul 26, 2005
MegaHurtz's Avatar
^^ yep
I don't know if there would be a fuse, but either way there is a wire that needs to be disconnected or cut or whatever, easiest thing to do might be to find a wiring manual for your alarm
Old Jul 26, 2005
skipbarber's Avatar
^^it's a viper, all DEI alarms have an inline fuse unless it's meant to drive a relay, in which case it would be a negative output. But I know for a fact that the 600 has a fuse running on that wire because it's a positive output.
Old Jul 28, 2005
gimmegimme's Avatar
gimmegimme is an unknown quantity at this point
I'm not familiar with the specific alarm, but if that wire is cut/disconnected, won't the parking lights not flash at all? Even when something sets off the alarm? (Maybe that's what you want?)
Old Jul 28, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Remove your running light, the turn signals dont flash its the running lights. Its the little bulb next to the turn signal that does nothing. Your turn signals will work as your running lights anyway.
Mucklow
Aug 22, 2015 06:28 PM
18
Aug 17, 2015 08:02 AM
JetsterDajet
Aug 16, 2015 01:56 PM
martinsmartin
Aug 15, 2015 07:34 PM
mrwhos
Aug 11, 2015 02:03 AM
