My car wont charge....please help
Old Jul 21, 2005
alpinecivic02's Avatar
alpinecivic02 is an unknown quantity at this point
FOr some reason my battery light came on and my alternator stopped charging....so me and my friend bought a brand new one and now the light is still on and it wont charge the battery....and we know it's not the battery....we also checked the fuses and everything is fine...the car will run for a while, but wehn i turn off the car and try and start it again, it wont(dead)...so what else could be wrong...please help....hopefully someone with the same symptoms can help
Old Jul 21, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
how do you know its not the battery??
Old Jul 21, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
somthing might be grounded out. but you better hope not cuz that'll be a bitch to find, untill your car blows up.
Old Jul 21, 2005
cambo's Avatar
I wish I was asian
does the civic have a voltage regulator?
Old Jul 21, 2005
cambo's Avatar
I wish I was asian
Actually, now that i think about...it sounds like its a dead battery. Although it might show 12-16 volts, the amperage might not be enough to start the car. Take the battery out and bring it to pepboys/autozone/advance auto parts and have them check the battery.
If the alternator was dead, the car would only run for as long as the battery was able to power the car. Remember that the car needs 2 things in terms of electricity, volts and amperage.
Old Jul 21, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
or it could be that even though the new alternator is ok, its not juicin the battery because of the connections. did you have the old one tested before you got the new one? cause its free to test. when you hook up the alternator make sure you connect the leads to the right place. i know it can be a pain cause of where the alternator is located. i wanna know how it turns out. if its not recharging it could be that one of the leads from the alternator to the batter is corroded or broken somehow. good luck.
Old Jul 21, 2005
ciVictoria's Avatar
I believe it is the battery I could be wrong though.
Old Jul 22, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
OR you can just go to autozone or discount auto and they check it for FREE. Can't believe you changed the alternator without checking.
Old Jul 22, 2005
jeepers2xxx's Avatar
jeepers2xxx is an unknown quantity at this point
i went throught 2 alternators in 1 month. just replaced the second one last nite
Old Jul 22, 2005
MegaHurtz's Avatar
it's the alternator
to test, start your car with the battery disconnected, then when it is running, disconnect the pos terminal. if the car shuts off or stumbles, it's the alternator. if your batteries won't charge i almost gaurantee you it is anyway. one battery failing to hold a charge is possible, but a double battery failure, especially with a brand new one, is near impossible.
Old Jul 22, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
He doesnt have a brand new battery, he has a brand new alternator and the same battery. Unless your battery is a deep cycle, then it's crap because it's been drained completely. You are supposed to replace the battery and alternator together, so I would get the battery checked out.
Old Jul 22, 2005
i will try hooking up a different battery to make sure...and btw we did try and go get it tested through autozone/pepboys/and kragen....but no one had the program or the plug to run the alternator...so i was unable to test..and kragen just decided to replace mine for free neways(lifetime warranty since it's not my fault they dont have the program)...im not that stupid to just change my alternator...without testing....
Old Jul 22, 2005
zen_master's Avatar
waitttttttttttt..
are the dash light indicators turned on when the keys are not inserted???
Old Jul 22, 2005
the only light that comes on is the battery/charge light when i start the car...
Old Jul 22, 2005
cambo's Avatar
I wish I was asian
but they turn off after the car is started right?
Old Jul 22, 2005
no the light does not go off after the car is started...it stays on and lit constantly
Old Jul 22, 2005
allmotor's Avatar
nor cal 7thgens
sup bobby i thought u were sellin ur car?
Old Jul 22, 2005
ragingSPAM's Avatar
I just burnt my tongue
its most likely the battery...cuz it can hold 12 volts but it wont have enough juice to crank out about 200amps for the starter to work over...just had this problem yesterday with a friends truck
Old Jul 22, 2005
zen_master's Avatar
goddie that ur not having my problem..
all dash light just turned on...and i can't start my car..
turns out, after playing around with the stuff inside the car, two fuses blown...and that's when i can start my car again...
but now, if i try to replace the blown fuses, the same dash light comes out again.....
Old Jul 22, 2005
MegaHurtz's Avatar
doh yeah if you already replaced the alternator, try the battery next and see what happens
amybe it was the battery all along and the alt was fine?
Old Jul 22, 2005
Mystic3030's Avatar
Battery light only comes on when the alternator is dying...I know, it makes no sense.
Old Jul 22, 2005
ragingSPAM's Avatar
yup...
Old Jul 22, 2005
mine was the alternator. damn AEM pullies wont turn the alternator enough so I went back to stock pullie
Old Jul 22, 2005
well i check my optima battery...and its fine...light still comes on and there is no charge going....so off to the shop it goes i guess first time ive ever had to do this for my civi....thanks neways guys...if you have any last minute ideas...let me know
Old Jul 22, 2005
allmotor's Avatar
nor cal 7thgens
bobby u goin to cmi?
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
