high output alternator
Old Jul 14, 2005
burke420's Avatar
The World Is Yours!
my system keeps shorting out or something at like 20 on the Alpni HU. and i was wondering where i can get a higher alternator since i have a 13W7 and 1000 watt JL amp. i think my laternator is shot. i need some good places to get like a 180 amp alternator.....????....any help will be greatly appreciated...holla!
Old Jul 14, 2005
eye_see_you's Avatar
let the devil out
i'm running a jl 500/1 300/4 Clarion DVD etc HU and still don't have a issue I think you might just need to add a cap in. After I installed my Aluma Pro 5 Farad cap there have been no issues at all. Unless you happen to just strain your alternator to much and it was weak to begin with.
Old Jul 14, 2005
suthurnlatino's Avatar
suthurnlatino is an unknown quantity at this point
Are you sure thats the alternator? I had a Alpine 9847 that the power kept going out on before I got a sub and 800W RMS amp. I had to replace it 3 times before the problem was solved.
Old Jul 14, 2005
MegaHurtz's Avatar
if your alternator is pooched your car will shut off completetly, not just your sound system... check your install first to see what the problem is. a cap will most likely not fix it, so keep that as a last resort
Old Jul 14, 2005
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
is the car on or off when its doing this?
also, make sure the ground is good, thats a common problem, where is it grounded?
Old Jul 16, 2005
Wizkid's Avatar
Wizkid is an unknown quantity at this point
I agree with the grounding problem. I had my XM Radio ground work loose somehow and it would randomly short my system out until I found the problem.
jzhartman
22
Jul 23, 2015 10:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
silentz
Jul 9, 2015 08:16 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
