fiberglass insulation?
Old Jun 17, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i know that when i used to build home speakers, it was always good to put r12 (fiberglass insulation, used in attics a lot) in the enclosure, is that better for sealed enclosures? the reason why i ask is because for some reason my sub doesnt hit low tones like it used to, it makes me wonder if A) it's out of phase, B) theres too much resonance in the enclosure, any ideas?
Old Jun 19, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
has anything changed with the wiring since it stopped hitting the lows like it use to?
Old Jun 19, 2005
booba5185's Avatar
nope, everything is the same, it just doesn't hit lows like it used too
Old Jun 19, 2005
booba5185's Avatar
anyone even have any idea what i'm talking about doing?
Old Jun 19, 2005
I know some box builders use polyester stuffing to "fool" the speaker into thinking that the enclosure is bigger. Since the wiring hasnt changed, I would bet its resonance in your box canceling out some of the low end. When I built my FG box, I coated the inside of the box with spray on rubberized truck bed coating so their would be less standing free waves. Basically filling the enclosure or coating the walls of it with something that will result in an uneven surface will help cut down on resonance.
Old Jun 19, 2005
booba5185's Avatar
the only problem i could think off is that it might change the volume of the enclosure
Old Jun 19, 2005
yeah it will, but sealed enclosures can vary by up to 20% without a noticeable affect in sound output
Old Jun 19, 2005
booba5185's Avatar
i was thinking of build a ported enclosure also, now could i use my current sealed enclosure, and cut a port to the correct size?
Old Jun 20, 2005
nope, ported enclosures need to be built to a specific size based on the frequency you want to tune the box to. Ported boxes have very tight tolerances for volume of the enclosure
Bruce2
Sep 27, 2015 08:45 PM
General DIY
Sep 25, 2015 08:02 PM
KronikScott
Jun 9, 2015 08:00 PM
djdefcon
17
Apr 6, 2005 11:52 PM
Ichiban
Mar 1, 2002 01:45 PM
