2 battery questions ?
Old May 19, 2005
travjkytt's Avatar
travjkytt is an unknown quantity at this point
I was wondering how you would run 2 batterys. Keeping it on a 12 volte system.
My buddy will be runnig 2 optima yellow tops batterys. so if you know how to run them please let me know.
Thanks.
Old May 19, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Yeah I have been wondering this too, For my system im gonna be running 2 optima yellow tops also, I should upgrade my alternator too huh? Hey sorry for the thread hijack but any brands good for "performance" alternators? Im gonna be pushing close to 1000 watt rms, and ideas?
I figured it was + to + and - to - but I dont wanna screw it up.
Old May 19, 2005
jeffsta17's Avatar
Bump!
Old May 19, 2005
Ed's Avatar
Ed
1kw rms isn't too much, your stock system should be able to handle it for the most part, it depends.
For two batteries, you can get an isolator to let you only drain from teh second battery, most useful for running the system with the engine off. It can also be useful just to wire the battery in parallel in the trunk, close to the amps.
http://www.bcae1.com/battiso.htm
Old May 19, 2005
travjkytt's Avatar
well see, my buddy is going to be running his sound system which is about a 1000 watts rms. plus, he is going to be running two compresiors now for his bags,before he was running only one.
he is also looking into putting a carputer in his car. so thats why we were woundering if we should run two batterys and not one. and if so how. thanks
Old May 19, 2005
MegaHurtz's Avatar
use an rv solenoid (not an isolator) to seperate the 2 batteries
rv solenoids are very efficient whereas isolators are not
Old May 23, 2005
jeffsta17's Avatar
What would happen if I ran without an isolator or a RV solenoids, I saw a diagram on that site that said how to do it, so is there any downsides to it?
Old May 23, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Very true, You can trigger the solinoid from your ignition, so when the car is on both batterys get charged. When the car off is the batterys are seperated. I have two batterys for my system although Im am not running the solinoid, its the proper way.
Old May 23, 2005
ex_03's Avatar
Godlike member
To answer your Q, I have done this on many vehicles the only down side to this is if one the batterys starts to die (wont hold charge anymore!) then it will kill the other, becuase the good battery will try to charge the dead one!. Now I have this in my old probe and I ran 4 deep cycles with a regular acid battery up front, never had a probelm but all batterys were brand new to begin with.
Old May 23, 2005
ex_03's Avatar
Godlike member
but seriously you can use a dare I say a FORD! mustang or escort starter solinoid there 25.00 USD at any parts place!
Old May 23, 2005
jeffsta17's Avatar
So if I got 2 brand new optimas I could just wire them positive to positive and the alternator would charge both or do both batterys need to have the alternator connected directly?
Old May 23, 2005
Ed's Avatar
Ed
they'll both charge.
Old May 25, 2005
ex_03's Avatar
Godlike member
what he said^^^Like I said thats the way Im running my car right now,no problems. But if one of the batterys dies I wont know which one untill I yank it out and test it, just kind of pain in the butt.
Old May 26, 2005
WhiteRabbit's Avatar
Thanks.
how you wire them together will be dependant on what kind of perforamnce you want, or what you want to do with your car. so the first question is, what do you want to do that warrants a second battery, or what do you want the second battery to allow you to do?
answer that, and then we can tell you the best way to wire them up
Old May 26, 2005
jeffsta17's Avatar
Alright well I want the front battery to run the car, and its crap, and I want the second battery to run my... 2 12's, 2 450c viair compressors, and my speakers.
Old May 26, 2005
then a diode isolator is really the only way its gonna happen. any other isolation or non-isolation method to wire them together will result in both batteries running everything. the rear will run the car, and the front will run your ocmpressors
Old May 26, 2005
jeffsta17's Avatar
ok so say it didnt matter which battery did what, my main goal is just to have enough power to run everything with no more dimming headlights and other crap.
Old May 26, 2005
alright, im not sure about the compressors, that might be an alternator fix. the only real way you will be able to determine that is by actually putting the batteries in and testing for dimmage.
certainly your audio system merely needs a cap or two or three to eliminate dimming.
I think your yellowtops will help for sure. They run at a higher voltage than standard batteries, so a voltage drop will result in less severe dimming. However, I personally think you will still get that minor dimming een with a pair of yellowtops if you are running compressors. they take LOTS of current!
I would almost think that due to the nature of the current draw, you would invariably be reverting to battery voltage when your compressors click on. so thats a tough call.
I wouldnt expect a fix, just a reduction operating a pair of yellowtops. and since dimming is your goal, you can simply wire the two batteries together in parrallel. no need for an isolator!
Old May 26, 2005
jeffsta17's Avatar
Alright so I run the 2 batterys with 2 gauge wire connecting them? I figure the bigger the better.
Old May 26, 2005
ex_03's Avatar
Godlike member
Yes the bigger the better, less resistence!
jferristx
Jul 8, 2015 10:09 PM
BootyDo
Jul 7, 2015 06:06 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
viper775
Dec 9, 2001 10:52 PM
