2003 Civic LX 4DR Trying to put Components
Old May 18, 2005
suthurnlatino's Avatar
suthurnlatino is an unknown quantity at this point
I searched the forum and I found some members saying how they got EX sails with the tweeter to fit their cars and I wanted to try the same thing but when I went to the dealer they told me that it would not fit my 03 civic lx 4dr sedan (newer civics than 01 apparently have the tweeters on the door panel on top of the window power controls). So is the guy on point or he doesn't know what he's talking about? I really wanted to put a component speaker in the front without using the Q-form kick panel things from crutchfield($150 a piece). If anyone knows any other methods I would really appreciate it. Thanks for anyone's help in advance.
Old May 18, 2005
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
From what I've heard, they won't fit the sedans. I just did this with my coupe and they fit perfectly.
You could always surface mount them on your existing sail panels. A few members have very nice surface mounts. Gearbox is the only member that comes to mind at the moment.
Old May 19, 2005
jttegx's Avatar
OMNES AD UNUM
its possible if your willing to do some custom fitting. it can fit, but making a flush and clean install is the hardest part.
i never seen the 03 sedan without tweets, so i cant compare.
Old May 19, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Install the tweeter in the door panel right next to the handle.
Like this
TripleDoubleLegs' quarts
Old May 19, 2005
I would rather try to cut a hole in the sail since it is cheap to replace. I don't know how much the doorpanel plastic would cost to replace (if i were to trade in the vehicle for an 06 or something). Is it feasible to cut in the sail panel or will i just end up messing up the mirror wires?
Old May 19, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
if it really came down to a trade in just offer to swap someones door panel w/o holes. Im sure theres some member out there who would take free components off your hands
Old May 19, 2005
BassKadett's Avatar
Its damn near impossible to cut the sail to fit a tweeter. There isn't any room back there with the wires.
Old May 20, 2005
J187's Avatar
Right concept wrong choice of words. Its totally impossible
Old May 20, 2005
J187's Avatar
You could flush mount it.
Old May 20, 2005
BassKadett's Avatar
Thanks for clearing that up.
Old May 20, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Or you could take the blank OEM sailpanel, put a surface mount tweeter holding ring that comes with your components on it with some hot glue, cut out the inside of the sail panel behind the ring, then wrap the visible portion of the sailpanel in some thin fleece or other material like an old tshirt, put some resin on it, lightly sand it once dry, and spray with black texture paint....and you have a custom, flush, nice looking (if you take your time) sail panel.
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
Gl3n1234
Apr 18, 2015 01:51 AM
deus-ex
Apr 13, 2015 12:29 PM
