Headunit won't accept CD problem
Old May 7, 2005
kalm823's Avatar
kalm823 is an unknown quantity at this point
I just finished installing a Dual XDM-6820 Head unit in my Civic, and when I power it on, everything works fine until I try to put a CD in. I can put it in the slot but it doesn't accept it. It can eject the partially inserted cd fine, so there's power going to the motor. I hooked up the wiring harness correctly, and the antenna as well. Does anybody know what would cause this? Did I get a defective headunit? Thanks in advance
Old May 8, 2005
Rennen's Avatar
New Mod on the Block
sounds like you have a defective head unit.
Old May 8, 2005
ssmotor's Avatar
ssmotor is an unknown quantity at this point
I agree, my pioneer had the same problem. Good thing i bought the warranty. They didn't even checked the receiver instead just offer me credit toward a new unit.
Old May 8, 2005
MegaHurtz's Avatar
sounds like defection
Old May 8, 2005
kalm823's Avatar
After playing with it for awhile, I figured out that you can reset the cd unit by holding the eject button for 3 seconds. After a combination of cd unit rests and head unit resets, it finally worked. Mods, you can lock this.
Old May 8, 2005
cambo's Avatar
I wish I was asian
dual isn't exactly the best of the worst brands if you get my drift...
you'll probably have to reset the headunit quite a bit in the future...
GolNat
Sep 10, 2015 08:25 PM
ImmortalEX
Jan 2, 2002 08:45 AM
LJ
Dec 10, 2001 10:48 AM
Foom
Dec 6, 2001 01:11 PM
AB
Nov 17, 2001 01:51 PM
