adding to fuse box
Old May 6, 2005
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
adding to fuse box
to add a + wire to a fuse on the fuse box u just remove the brass screw and connect a wire 2 the back of an open contact am i correct in saying this?
Old May 6, 2005
stepchild's Avatar
stepchild is an unknown quantity at this point
I have an 01 LX and I just found an open bay in the fuse block itself checked the open bay with an ohms meter or meter reader ($20 @ radio shack) and went from there. Use one side or the other of the open bay. I tried to use both sides and my parking lights came on?!?!?! but they turned off when i used one side or the other. By open bay I mean a place in the fuse block were there is no fuse but a place for one (that has current going to it)good luck
Old May 6, 2005
stepchild's Avatar
.....and by the way if its a constant (12 volt + wire), not accesorywire, make sure its fused. And that all depends what your powering from your fuse box........
NoobyKid
Jul 18, 2015 02:01 PM
beeemerdude
Jul 10, 2015 09:22 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
