7" Component Midwoofers in Doors? Vifa Pl18
Old May 6, 2005
Rollingstash's Avatar
Rollingstash is an unknown quantity at this point
I've got a set of very nice components that I would like to put in the front doors of my 01 EX coupe. The woofers are Vifa Pl-18's, and are a 7" woofer, and I'm wondering what the chances are of fitting them without hitting the window or the door panel. The speaker dimensions are as follows:
Dimensions: Overall Diameter: 7-1/4", Cutout Diameter: 5-3/4", Mounting Depth: 3".
I plan on making an adapter plate out of MDF, but I need to know how much room I have inbetween the metal and the inner door panel, and how much space I have behind the metal without hitting the window. Thanks!
Old May 6, 2005
acidbaby's Avatar
The Beez Kneez
i would say use the qforms kick panel instead for your 7inchers..
a 2 way in the door then highs up top...
Old May 6, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Bad news for both of you.
1. you are going to have a hard time with a 3" speaker that size
2. You are not going to fit a 7" speaker into a Q-form. Some 6" speakers won't fit - they were designed for 5 1/4s and can accomadate some slightly larger woofers.
You can try a 1" MDF spacer, but I believe you'll have to cut the plastic on the back of the door trim panel.
Sep 3, 2015 07:01 PM
swaff39
Aug 11, 2015 07:16 AM
glockma630
Aug 1, 2015 10:30 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
ballmich
Jul 9, 2015 11:59 AM
