is 100sq feet neccessary?
Old May 3, 2005
mr_fobster's Avatar
well i just cant stand all this rattling im gettiong from the back so ive decided to get some fatman sound deadening. and saw on ebay(after reading and searching on DIY sound deadening and wat not here on the boards) 100sq feet of fatman mat. i would be doing some of my front doors to but the main place where all the rattling is coming from is the rear deck, and the trunk lid..and some of the front door panels. so you think this would be too much for wat im gonna buy and too little? sorry i cant measure my trunk and evrything else right now cuz im stuck here in class at school(college buisness communications class)
Old May 3, 2005
bickford05's Avatar
bickford05 is an unknown quantity at this point
100sq ft is alot. I did the full floor, front doors, full trunk, the sides, and some of the firewall, and i have some left over. unless you want to do more than one layer, i would say you dont need 100sqft
Old May 3, 2005
mr_fobster's Avatar
^^^ wow thats alot....hmmm maybe i can use it for more than one layer....thanks for your help
Old May 3, 2005
Rufus's Avatar
I used about 100+ sq ft of dynamat extreme
Old May 4, 2005
paradoxblue's Avatar
expensive
Old May 4, 2005
Rufus's Avatar
THAT is true. Even wholesale was what 80 bucks a box? I think...
Old May 4, 2005
alex053's Avatar
i did the back half of my car and the doors with 44 sq feet.
Old May 4, 2005
mr_fobster's Avatar
well im getting 100sqft of fatmat for $100....is that too much for 100sqft? sorry cuz dynamat is expensive....cuz for 50sqfeet i saw this one place selling for 100...and saw fatmat and heard good stuff about em so might as well.
but how much mat comes in one box?
Old May 4, 2005
isnt there crap uc an get at hardware stores built for floors that works?
Old May 4, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Lots of posts in two threads about this, so I won't go into it here.
As far as your original question, 100sqft is a little much if you are not doing the floors...BUT DO THE FLOORS!
You will notice considerably less road noise while on the highway, since your engine's and tires' noise will be muffled as it richochet's off of the cement on the road (asphalt is not a noise problem)
Also, it's really easy-since you will have the side panels off anyway, why not take up the seats and carpet?
Finally, either way, use more than one layer. Most of us sound deadening deciples use AT LEAST two layers, especially on the problem areas (wheel wells, doors).
Old May 4, 2005
Hurts2bStock's Avatar
Shinier than yours, meatbag
ok to very mildy hijack for one second......sound deadening is my next mod planned too............if you do the usual amount of sound deadening, do you get a completely rattle free car? or am I dreaming....lol
Old May 4, 2005
tripledoublegs's Avatar
Euro-Spec
YOU CAN NEVER HAVE ENOUGH SOUND DAMPENING MATERIALS!
I would say 100sq ft is perfect, and I would suggest to put 2 layers on your doors, and 2 layers on your rear deck. The rest, use it for floors, trunk lid, etc...
Old May 4, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Hurts, you'll never rid yourself of rattle, expecially in the rattle traps out cars are... You'll be able to do lots of justice with that much though.
To the thread starter, I used 100 sq ft from my rear seats back. I double layered the trunk. Noticed a difference. I also used another 100 from there forward, along with adding carpet padding under the existing carpet. The rear deck is notorious for rattle. Make sure you put 2 good layers on top it it (between the plastic and the metal. Heck, for good measure I'd glue some type of fabric up there (I uses industrial carpet because it's thin. You could even use fleece. Spray glue on top of the mat deadener and then stuck it on. I've seen people carpet the rear deck (I believe Rabbit did this). keep it frmo contacting the metal and vibrating against the rear window and you'll elimintate a lot of the rattle there.
Old May 4, 2005
Bires's Avatar
not if you keep hitting potholes with your 2" drop!
Actually, if you sound deaden your car...you will hear MORE noise! (initially)
Your engine will quiet a little
Your road noise will drop in pitch
Your cabin reference acoustics will quiet and you'll hear little noises you didn't realize were there.
That being said, with some work, you can kill any little squeaks and clicks you will hear.
If you pad your plastic panels properly, they will push against the sidewalls and metal and stay in place better, rather than move around.
Old May 5, 2005
mr_fobster's Avatar
well yea imma be doing the rear deck first off cuz thats where my main rattles come from(and thats why i just listen to nothing when i drive, i.e. no radio, or music, just my intake sound from the engine...lol) welp ill be getting the fat mat soon so ill prolly post pics when im done.
Old May 5, 2005
Rufus's Avatar
put grease around all of your plastic clips on your rear deck before you put it back on.
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
CivicAK
Aug 28, 2015 10:16 PM
Uan
Aug 23, 2015 03:03 AM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
TAZZ
16
May 15, 2002 04:36 PM
