trunk rattles
Old May 1, 2005
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
trunk rattles
can ne1 tells me more about trunk rattles?
i mean it sound as if the plate is touching the trunk..i just noticed something else..but would like yall opinion about it b4 i can assume..
Old May 1, 2005
paradoxblue's Avatar
try searing. there are diy on sound deading the trunka nd the break light area. and yes the licenses plate rattles
Old May 1, 2005
WhiteRabbit's Avatar
you can find all this by searching, but I would start with the trunk lid itself. you can use foam to prevent the plate from hitting your lid. That'll kill the liscence plate rattles.
for the trunk lid, id use spray foam. you can get a can from home depot for five bucks. dont forget to mask off your rear windshield and open trunk while spraying, its REALLY sticky!
if you fill the gaps between your trunklid skeleton and trunk lid about 75% or so, and let that expand out, that will get a bunch of the rattles out.
Old May 2, 2005
2slow2run's Avatar
wut time is it now
i was just mess'n around n notice how when i apply pressure to the trunk it doesnt rattle n have a nice bass sound....so like wutta bout the spoiler? needs bout like 50lb of pressure to seal the trunk so the plate doesnt really rattle
so like i sat on the trunk n the rattle stop..then hop back down n notice how it rattle
Old May 2, 2005
I dont know anything baout how to deaden spoilers, im sure someone else will be able to answer that
Old May 2, 2005
2slow2run's Avatar
wut time is it now
like if a spoiler is bout 50lbs n is well screwed to the trunk then itll apply pressure but also should have like fruit of the loom surround the area where is screw on u think itll work like that ?
as long as the trunk is shut tight rattles doenst occur and those dynomat thing i dont noe bout those..
1 of the guys in here must have it..i wanna c wuts the outcome if u have it
Old May 2, 2005
2slow2run's Avatar
wut time is it now
well u should try sitt'n on the trunk n ull c wut i mean...have the stereo blast n bass up..then listen for it..then sit on it then hop off n c wut i mean
Old May 2, 2005
I'm sorry, I dont mean to be rude, but I couldnt understand much of either of those two posts. could you rewrite tham?
If I understand corectly, you are suggesting a spoiler might help prevent rattles? It's a rattle liability, not a corrective. But I may have minsunderstood what you were trying to say.
Old May 2, 2005
okay, buddy translated for me, is it right to say you are suggesting that a good seal between the lid and body through the rubber grommet should be a sufficient rattle prevention, and that dynamat is something you are curious about the benefits of, given that the spoiler adds weight?
unfortunately, its not that simple. the major rattlein your car is probbaly caused by the lid skeleton vibrating agasint the trunk lid skin, and not the lid as a whole agasint the frame as a whole. pushing on the lid helps, since that will mash the skin into the skeleton, preventing their rattling.
dynamat may or may not help. I'm sure there are cases where dynamat has been successful, but Ive talked ot folks in here who were wondering why dynamat didnt help them! dynamat wont prevent lidskin and lidskeleton contact! So chances are, it wont help! the danger becomes what happens if you try dynamat and it doesnt help? now youve covered your access points to spray foam! just more work to cut out all the holes of dynamat to spray the foam...
I like dynamat, I really do! But I would spray the foam first, THEN lay the dynamat to make the inside of the lid look better.
but no, the weight of a spoiler wont prevent rattles, you'll get the testimony of dozens of members here telling you their spoiler actually added to the rattling!
Old May 2, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I have dynamat, its quite effecitve, insulates the sound better but my trunk does still rattle
Dynamat works, I think our cars come stock with a similar material look under the trunk carpet I think on the right side of the spare wheel.
Well when I had it installed I went all out
Dynamat
Full trunk (sides, lid, under carpet metal)
Rear Quater Panels
All Doors
Behind rear license plate
Audioheaven did the work and did it well, took there time too.
If anyone wants pics I got some on my computer but nowhere to host em so just leave your email adress and I can show you.
As far as a spoiler reducing rattling, yes but I could only see it helping on the out side noise, if you push down on your trunk the bass will sound cleaner and have less rattle. Since I have no desire to purchase a spoiler I stopped caring about what my car sounds like on the outside, im happy with the inside.
I thought it always be funny to have a bumper sticker that said
"If this trunks rattling...
its just the midjet in the trunk trying to escape"
Old May 2, 2005
vietstylez's Avatar
lol.. a 50 lb spoiler? u're nuts
Old May 2, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
1. Search, there's a sound deadening DIY, look in the new sticky Megahurtz has at the top of the page.
2. One way (before doing any mat type deadener) to help is to move the trunk latch (which is in the DIY section at the top of the page when you click the DIY button) to tighten the seal.
3. Foam the lid (b/t skeleton and lid(as rabbit suggested).
4. Foam the back of the license plate.
5. Do the sound deadening DIY.
Old May 2, 2005
2slow2run's Avatar
wut time is it now
daym n i thought the license plate frame "hit me i need the $$" was dangerous" lol
but may u guys r right well thankx for the oppinions
n yes the frame does work..ppl intend to hit me
Old May 2, 2005
hoyl crap.. people rag on me for my spelling.. im not that bad lol.
but now i know how they feel
yeah tighten the lid. you dont need a 50 pound spoiler.. really.. you dont.. seriously
Old May 2, 2005
2slow2run's Avatar
wut time is it now
nah i was just say'n bout the 50lbs spoiler..lol
it doesnt even come close does it?
thought so
Old Sep 28, 2005
krossfyah's Avatar
krossfyah is an unknown quantity at this point
i got foam on the trunk inner panel
foam is hard to come off
whats a good technique to get the foam off
it looks bad
Old Sep 28, 2005
MegaHurtz's Avatar
please don't dig up dead threads.
Crazygrlinak
Oct 8, 2015 05:06 PM
rovafa2002
Sep 28, 2015 06:57 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
fvckbg
Sep 8, 2015 09:55 PM
