adding to the fuse box
Old Apr 29, 2005
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
ok this is my first car so im really not used to it but i want to connect 2 blue leds to my fuse box and i was reading alot of stuff saying how you just connect the + under the streering colum and i found the fuse box and i dont understand what do 2 now do i need to open the gray box and wire it up behind it and how do i do this or is there an eaiser way thanks alot
Old Apr 29, 2005
ncirom2003's Avatar
why do you want led's in your fuse box?
for an answer let us know where you plan on mounting the led's and how and why
Old Apr 29, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
hmm... I think I know what you mean. Your looking for an inline fuse. Nothing to do with the fuse box. You need a fuse that you can tap into a wire, allowing for a fuse to be connected to that power source. No Need, If your running under dash led's or neons. Just wire then to the power outlet/cig lighter, it is already fused. It will work.
Old Apr 29, 2005
ok so this is basicaly what i want to 2 im going 2 connect 2 blue leds so they light the footwells and im going to connect them on a switch and then i was planing on going to the fuse box because i really dont want to connect it 2 the cig adapter power i would rather have it independent basically whats the easyist way i can do this
Old Apr 29, 2005
Blahman240's Avatar
it'll be just as good if you go to the lighter. It'll be better then trying to mess with the fuse box. It will be independent. And Always active if the car is on.
Only thing about this though, I think it wouldn't work if the car is off. Hmm.
Old Apr 29, 2005
Blahman240's Avatar
Actually... Now that I think of it.. I don't think there is a wire you can wire it to that will allow it to always be on... Besides the dome light.
Old Apr 29, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
well you could wire them directly to the battery... or headlights... or to the dome light if you want them to work almost constantly... you best bet though i splicing in the cig lighter this way you never accidentaly leave them on
Old Apr 29, 2005
thats why i was gunna connect to the fuse box because i want them to turn off with the car and i dont want to cut and wires
Old Apr 29, 2005
LowSky's Avatar
so you rather solder the wires to you fuse box then to cut the wire to the cig lighter
Old Apr 30, 2005
ncirom2003's Avatar
no he could solder it to the fuse tap and plug it in, i talked to him bout it and his ideas will work
Old Apr 30, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
I connected them with my headlights, so when I turn on my lights at night they come on at the same time.
Old Apr 30, 2005
ncirom2003's Avatar
i like your avatar 05reverb hahahaha
Old Apr 30, 2005
Blahman240's Avatar
I'm wondering how I'm going to wire mine up now... I think wiring them to the battery would be cool, cause it could be on when I'm parked. But whats the point? I don't know... I gotta figure out what I wanna do.
Old May 1, 2005
CraigW's Avatar
A good source for a low current, constant voltage is at the headunit connections. (which can be tricky on the Civics)
You should try to install smaller value in-line fuses on all work done.
NoobyKid
Jul 18, 2015 02:01 PM
beeemerdude
Jul 10, 2015 09:22 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
