cutting sheet metal
Old Apr 20, 2005
jack123's Avatar
jack123 is an unknown quantity at this point
cutting sheet metal
I have components that require a bigger speaker hole in the front door. What tools did you use to cut the slits in the metal? I know most people here said they use a dremel, but I don't want to buy a dremel since I probably won't have much use for it after this. Do they rent dremels? Or what are other tools I can use? Is there a bit for a drill that is good for cutting sheet metal?
Old Apr 20, 2005
MegaHurtz's Avatar
buy a dremel, it will pay itself off for the few times that you do use it, they are awesome
Old Apr 20, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
70 bucks a walmart?!!?!?! any ideas where to gte one cheap?
Old Apr 21, 2005
dalaiLiam's Avatar
dalaiLiam is an unknown quantity at this point
dremel is Ok, You could also use a jigsaw with a metal cutting blase, granted you'll have a time de-burring the edges.
Old Apr 21, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Originally Posted by jack123
. . . but I don't want to buy a dremel since I probably won't have much use for it after this. . .
You probably aren't thinking of all the uses. But I don't know anyone who wouldn't benefit from owning one. Check online for some of the uses - they aren't just for modifying cars. Hell, they're starting to use dremels at the place where my chick gets her nails done. You should be able to find a basic dremel for $40-50 maybe cheaper.
Also, if you are deadset against getting a dremel and have no other options, if you are careful, you could get away with drilling a bunch of holes in line real close together and bending the metal with pliers. Although this IS kinda hack . . .
Old Apr 21, 2005
J187's Avatar
Problem with a jig saw is that it's kind of a pain in the *** to get a short enough blade or use it without the base contacting. It's a much easier task with a dremel or a pnuematic disc saw or metal saw.
Old Apr 21, 2005
jack123's Avatar
What model dremel do you recommend and what bit do you use to cut the sheet metal?
I found this dremel model for only $45 CAD, but I'm not sure if its powerful enought to cut through the metal, it max speed is only 13,000 RPM:
http://www.homedepot.ca/escalate/sto...0207&view=spec
Dremel
MiniMITE 4.8V Cordless Rotary
A cordless rotary tool 4.8 V, with two speeds 6500/13,000 RPM. Uses 4 AA Batteries .Comes with 5 accessories for cutting, sanding, grinding, polishing.
Old Apr 21, 2005
fonto's Avatar
The LA Clipper
the dremel that i bought has to be the most useful all-around tool that i own. I just looked at all the dremels, and bought the best one that i could afford.
Here is a pic of the 6.75" speaker i put in the door...
Old Apr 21, 2005
jack123's Avatar
I'm sure its a very useful tool, but I still think I won't use it much after I cut this metal. Thats why i was wondering what other people used to get a nice cut in the metal. Everyone didn't use a dremel. I'd be willing to buy that dremel for $45 bux. Anyone else have that model? I'm not sure if its powerful enough to cut through metal.
Old Apr 21, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I go here for tools: www.harborfreight.com
Chick here to dremel like tools:
http://order.harborfreight.com/EasyA...ht/results.jsp
1. it is cheap $$ wise
2. Tools are good IMO
Old Apr 21, 2005
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
I have a plasma cutter. Cuts like butter!!
Old Apr 21, 2005
Ed's Avatar
Ed
THere's also the Black and Decker wizard, it's kind of a dremel knockoff. I don't use it much, but it works great.
I wouldn't recommend a cordless tool, they're just never powerful enough.
You could also look up a cheap metal nibbler, i honestly don't know how much they run, but it might be less expensive.
Old Apr 21, 2005
Ed's Avatar
Ed
http://www.harborfreight.com/cpi/cta...itemnumber=539
18 ga, don't know what the door panel is:-/
Old Apr 21, 2005
J187's Avatar
A metal nibbler is about $15 at Radio Shack.
Old Apr 21, 2005
jack123's Avatar
Thanks...i'll look it up
Old Apr 21, 2005
J187's Avatar
That's a good find. I might buy that to keep in my car in case some Ahole parks too close to me
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Bikergofast
Sep 12, 2015 01:36 PM
duhwubwub
Sep 10, 2015 11:00 AM
