Anyone do audio repair?
Old Apr 5, 2005
Rufus's Avatar
I have 2 power supplies from PPI DEQ-230's that do not work. One heats up like it's on fire, the other doesn't even power up. Anyone into fixing them?
Old Apr 5, 2005
Rufus's Avatar
nobody?
Old Apr 5, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
I rebuilt my crossovers when some of the solder spots snapped... I'd be willing to give it a shot, but I can't gurantee a thing as I don't really know what I'm doing, electronics wise. I know how to fix the crossovers, but for something more complex I might have a problem.
Old Apr 5, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
sounds like youre losing ground. check that ground again b4 hookin up another amp
as for power supplies, youll need to test all the MOSFETs in there.
MOSFET are usually identify as something like, IRFZ44(popular ones) or IRFZ34(older, less efficient)
Old Apr 6, 2005
Rufus's Avatar
Yeah I have no idea about this stuff. The power supplies also have the RCA input and output on them so I need to make sure someone is experienced in repairs. Nothing looks snapped, broken, etc.
Old Apr 6, 2005
profuse007's Avatar
Senior Member
check grounding.
Old Apr 6, 2005
Rufus's Avatar
I don't know enough about them to check ground on the board. My ground for the DEQ itself is perfect.
Old Apr 6, 2005
profuse007's Avatar
Senior Member
no, the actual grounding to chasis. it sounds like you have a lose grounding or bad one. excessive heat or auto shut off could comes from ground. this happened to my PPI and had to secure my ground down.
Old Apr 6, 2005
Rufus's Avatar
The DEQ's do not require it. Many audio installs would put them up in the dash without the shroud anyway.
Old Apr 7, 2005
profuse007's Avatar
Senior Member
i thot thats the model for an amp, looked at it again and its digital EQ for DEQ....
Old Apr 7, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
dallis, i'll open it up and look at it, i might be able to fix it
Mad Dog Tannen
Oct 19, 2016 08:12 PM
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 18, 2015 06:32 PM
Sep 27, 2015 11:33 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
