How to connect power wire for amps on 02 Civic?
Old Mar 30, 2005
spunger's Avatar
spunger is an unknown quantity at this point
Hey guys,
I was lookin the other day and saw that the Honda's battery is a top mount only. How can I hook up a amp wire (4 guage) to the positive terminal? It doesn't look like I can fit a ring terminal in so are there any good aftermarket postive/negitive battery terminals? Do you have to snip the factory wire and wire it into the battery terminal?
Just curious, pics/brands/anything would be helpfull.
Thanks,
Chris
Old Mar 30, 2005
wonderz's Avatar
wonderz is on a distinguished road
why can't u just open up the red cover and screw a ring terminal on the stock battery terminal?
that's like the easiest way. not the best looking, but easiest.
Old Mar 30, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Yep... just unscrew the nut on the positive terminal, and then just put the ring terminal on the positive connector, and tighten the nut down.
I have it setup this way, and yes I have 4 gauge wire too. I think a lot of people on this board do it this way. You could also buy one of those aftermarket connectors that allow you to put in raw 4 gauge wire without a ring terminal. I forgot what those are called though.
Old Mar 30, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
http://cgi.ebay.com/ws/eBayISAPI.dll...762803531&rd=1
http://search.ebay.com/battery-termi...Z1QQsacatZ3270
Old Mar 30, 2005
eye_see_you's Avatar
let the devil out
you can screw it onto the terminal thats there or use tsunami or stinger battery connects like I did when I cahnged to my optima yellow top replacement for the 02 vic
Old Mar 30, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Actually I think it looks perfect. Just cut the side of the red cap around the wire so the wire come right out the side. Looks more than fine.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
roverben
Jan 21, 2019 05:16 PM
Fastfebur
Apr 22, 2015 01:37 PM
2k2CivicEX
Nov 5, 2001 07:22 PM
NukeSilo
Nov 4, 2001 09:37 PM
