Advice on setting up my trunk.
Old Mar 29, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Ok, so, I'm walling off my trunk for aesthetics. I can't decide between two methods. Please comment, provide your reasoning and not just a flat opinion.
The floor is done, it just needs to be carpeted. I have trouble there. I am going to put a wall up and seal it to the back of the box, then put the woofers through so that only the woofers are visible. What I can't decide is; should I flush the wall up against the side
OR, should I just keep straight edges like so.
My biggest concern is simply how the bass will respond. I don't wanna seal my bass completely off from the cabin, so I'll leave a gap between the top of the wall and the roof of the trunk. But do you think I'd benefit from leaving the sides too. It'd be easier to leave the sides flat, but look a little better if I flushed it. I don't think it would look bad with the flat sides though.
Old Mar 29, 2005
MegaHurtz's Avatar
I like the first way ebtter
why not fire the subs into the cabin?
Old Mar 29, 2005
eye_see_you's Avatar
let the devil out
yea fire the subs into the cabin will be nice sound
Old Mar 29, 2005
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
My bloated opinion *hehe its not flat!* is seal off the sides AND top, toss in the subs and put in actual portholes *you can get the ones for boxes off ebay if you look every now and then, but I would put 2 or 3 down the center. The reason being is leaving the top open is gonna leave the sound sounding a little sloppier because where the air is coming from won't really be "controlled".
Old Mar 29, 2005
J187's Avatar
Because, A) I would have to rewire everything to move that box. And B) I tried it both ways at first and sounded much better firing into the deck lid. And C) I love the look of woofers showing through a wall
Old Mar 29, 2005
J187's Avatar
But the question is, do you think it will affect my bass response greatly by sealing the sides, or do you not think it will make that much a difference?
Old Mar 29, 2005
tripledoublegs's Avatar
Euro-Spec
I remember a few people saying sq drops dramatically when you build a wall like that, and fire the subs towards the rear. I'm not sure, I've never heard one of those setups yet
Old Mar 29, 2005
J187's Avatar
where did you hear this?
Old Mar 29, 2005
ncirom2003's Avatar
i know a guy whos done work on some cars that are worth 300,000 dollars and up (all on sound system) for db races. he also does tons of smaller jobs for people who can afford him. he said its best to aim it straight at the deck lid because the soudn will bounce off and amplify bouncing back into the cabin. as for the setup....its odd but im actually in the process of doing the exact same thing. im going to build a box put subs then mount a "wall" like you have and put a plexi grille on the subs. then on the other side im mounting the amp behind seats on box and sealing off that opening with a wall. (cut out for amp).
if the walls do block sound im screwed lol. post up finished pics though.
Old Mar 29, 2005
J187's Avatar
Well, I'm not necessarily worried about the wall blocking off the sound completely, I'm worried it might F up the sound a little bit
Old Mar 29, 2005
ncirom2003's Avatar
oh as for it sounding bad.... my fathers car has this setup and as long as you secure everything good and tight it should sount perfect.
Old Mar 30, 2005
J187's Avatar
Thanks for input so far guys.
BUMP
Old Mar 30, 2005
manahoonie's Avatar
i didn't see if anyone covered it, but beware that if you want to keep it flush with the sides, you may need to cut holes for the trunk supports, unless you want to drive around with your trunk open i like to keep things clean, so i like the first one better. just gotta make room for when the trunk is closed
Old Mar 30, 2005
J187's Avatar
Thanks manohoonie. Good look. I already factored that in, but a very good point nonethless.
Old Mar 30, 2005
ncirom2003's Avatar
hey keep us posted on pics of fit and finish and how you put it in and everything, did you have to put it in in two pieces or what? thanks since im doin same thing in my trunk. and incase you havent measured its 40" between the arms for the trunk to close.
Old Mar 30, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Personally, were it me, and I really wanted to "do a wall type effect", I'd probably go with the second. Actually, I'd much rather do an IB setup, and seal everything off, but I don't know your woofers, so I can't say how well it'd respond to that type of enclosure. For aesthetic purposes, I like the second method. Keep everything flush all around as opposed to having that small, useless gap. If all else fails, you could always do the box, but cut one of the boards to fit the contours, cut it out and plexi the opening and add some neon or something likethat to spice the appearance up some.
Old Mar 31, 2005
J187's Avatar
OH, I defintiely realize flush is better for aesthetics. I'm wondering if it will affect the sound to seal the woofers off from the trunk. I know about bass waves and how they won't be blocked, but will it affect the sound at all?
Old Mar 31, 2005
I'm sure it would being as airspace would be a tad different. Probably not an audible difference, but you'd probably see it on a mic.
Old Mar 31, 2005
J187's Avatar
*** the mic. The only mic I'm concerned about is my ears! Cool, I'm tryin' it. Thanks all.
18
Aug 17, 2015 08:02 AM
brainwashedmc
Jul 27, 2015 10:05 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
