help me decide
Old Mar 26, 2005
  #31
ExOrCizT's Avatar
ExOrCizT is an unknown quantity at this point
http://www.jlaudio.com/tutorials/index.html#
2nd link
Old Mar 26, 2005
  #32
ExOrCizT's Avatar
hmmm let me make shure just one more time, the one 12 inch with the 600 watts will put out more SPL than 2 10'' with 400 going to each?
Old Mar 26, 2005
  #33
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
No.. I said that the 12" will play lower frequencys better thats all, spl (sound pressure level) has many attributes that must come together to work properly. Starting with enclosure the manufactoror tech support will tell you the same thing I will, ported enclosure's will produce more spl versus sealed, but sealed plays more accuratly. Ported enclosures will also play lower frequencys better and are harder to build properly. There are many factors to spl such as sound deadening, power upgrades like alternater rewireing.From what I seen the IDQ12" goes into a rather small enclosure thats not going to sound all that great, compared to a sub that is designed for large enclosure. Im not saying that IDQ will sound bad but it sounds to me that you want every bit of sound you get right? I would go with something that is desgined for large enclosures. How much cubic air space do you have to work with?
Old Mar 26, 2005
  #34
ExOrCizT's Avatar
nah, i want punchy bass
Old Mar 28, 2005
  #35
ExOrCizT's Avatar
the question i have now is how should i hook up my subs, amp that i have now (refer to 1st post) to get max power?
Old Mar 28, 2005
  #36
ex_03's Avatar
Godlike member
if you went with one sub (the dual voice coil) then connect both pos to the pos of amp and then both neg's to the neg of the amp.
They are 2ohm voice coils so by wireing them in parralell it will give your amp 1ohm of resistance. Which is the lowest your amp can run at.
Old Mar 28, 2005
  #37
ExOrCizT's Avatar
no the setup i got now is ONE 2 channel amp (150 watts at 4 ohm X 2 ( 2 ohm stable for 2 channels) and 360 watts at 4 ohm X 1, and 2 subs 4 ohm SVC
Old Mar 28, 2005
  #38
ex_03's Avatar
Godlike member
not going to get all the power out of the amp, you need dual voicecoil subs that are 4ohm coils each. or you need an amp that is capable of 2ohm mono loads.
Old Mar 28, 2005
  #39
ExOrCizT's Avatar
heres how its hooked up now,
rember the amp is 2 channel, bridged
multimeter said 2.1 ohms
i set the gain to 26.9V
Old Mar 28, 2005
  #40
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Yes that is parelleled at 2ohms. But is your amp stable at that?
Old Mar 28, 2005
  #41
ExOrCizT's Avatar
i dunno... lol the fuses havent blown... i got a power accustik 620/2
Old Mar 28, 2005
  #42
J187's Avatar
According to power Acoustik, the amp is not stable the way you have it. Like EX said, you simply cannot do what you want to do with that equipment. You might be getting away with it, but it will eventually be the death of that amp. I vote sooner rahter than later.
Old Mar 28, 2005
  #43
ExOrCizT's Avatar
than how should i wireit
Old Mar 28, 2005
  #44
ex_03's Avatar
Godlike member
no its not, its a 4ohm mono amp as he stated up above but he could be wrong, If its correct you'll smoke the amp with that configuration.your amp is 2ohm stereo and 4ohm mono. Thats why there is no way to acheive the proper load for the amp to put out all power possible safely.
Old Mar 28, 2005
  #45
ex_03's Avatar
Godlike member
As I stated above you got the wrong subs or amp your choice. Which ever you decide to keep is up to you, You must iether get an amp that is 2ohm mono stable, or get dual 4ohm subs.
Old Mar 28, 2005
  #46
ExOrCizT's Avatar
in the future *ONCE I sell what i have" i will get the IDQ and the DI amp
but for now i gotta use what i have, so how should i wire it?
and what Voltage should i set my gain to?
Old Mar 28, 2005
  #47
ex_03's Avatar
Godlike member
One sub to one channel and one sub to the other channel. Follow? one on left and one on right. That will run it 4ohm stereo.From what I understand about most Headunits is this anything above 25v is clipping, Unless you have dual digital to analog converters (DACS) that are at least 24bit. If not the rule of thumb is no more than 25v. The rest is clipping or distortion.The reason being that most HU's that have dual dacs have high voltage output or built in line drivers. You can buy aftermarket line drivers audiocontrol makes them, but like I said before if your not competing in say "IASCA or USAC" just use what you have and go by ear, its the best way to know if your subs are getting distortion or not, then just back off the gain some.
Old Mar 28, 2005
  #48
ExOrCizT's Avatar
ok, what volage should the gain be set to?
Old Mar 28, 2005
  #49
ex_03's Avatar
Godlike member
try 25v and see if your subs are getting distorted when you turn up your radio.
Old Mar 28, 2005
  #50
ExOrCizT's Avatar
well
squareroot(150watt*4ohm) = 24.5
so thats what ill set it to!@
Old Mar 28, 2005
  #51
ex_03's Avatar
Godlike member
sounds good to me! let know how it works for ya.Hoped I help ya
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
charmon4815
General
Sep 22, 2015 08:00 AM
TheRiddicles
Sep 21, 2015 03:34 PM
