request: pics of "big-3" upgrade
Re: request: pics of "big-3" upgrade
DO NOT use 0 gauge wire for grounding. You will have serious problems due to higher resistance. 4 gauge is the thickest I'd use. I've done ground wire upgrade replacing stock ground wires, and optima battery. Noticed no difference. Added hyper voltage system to battery and noticed better response.
Ommggg more bad advice. I cant dude i cant 🤣🤣🤣🤣🤣. Chassis engine trans ground are to provide stable voltage thought the electronics that sit in the respective components. You became a premium memeber by spitting bs?
Sauce: lots of electrical engineering classes in undergrad, admittedly a long time ago. But physics hasn't changed much in that time.
This is correct. Lower gauge (larger wire) would reduce resistance. Not that resistance in wires this short is meaningful so long as they are sized appropriately.
Hi guys, newbie here.
Because our Civics ( my 05 does?) also have the power wire running from the battery to the starter should we also upgrade that or is it not necessary and just stick to the big 3?
Also can I just get a bigger sized terminal from Lordco to hold the two power cables due to new size cable or what exactly am I looking for to correctly do this?
Thanks for any help.
I Have 2 amps coming is why.
Sorry I just don't understand how the new power cable and stock starter cable should sit together on the positive post if the power cable is 1/0.Stock connector will still fit both or do I get a new connector or use copper lugs that will fit the battery post and stack them?
Stupid newbs eh! LOL
I think you might be getting ahead of yourself. Are you doing some crazy car audio or something else that you expect a huge electrical load?
I think you might be throwing your money at something that could be better spent elsewhere.
In that case, just add a ground line from engine to frame, and another one to the frame at the amps. Upgrade your positive terminal to support a power line for both your amps, and you will be fine. No need to upgrade any of the "car side" power wiring.
Speaking from experience, I ran a 12" alpine type r and a 500w sub using a ring terminal on the positive terminal nut. You will be fine.
Waste of time and money. Even if you upgraded your wiring, you would still be limited by your alternators output, among other things. All that matters is your power has a clean path to travel and isn't grossly undersized.
Now if you were running a bunch of sensors that were dependent on a good battery ground connection, then we would be having a different conversation.
I don't know if he still does them, but you can PM the thread starter here:
I bought my kit from him.
PM electric130, so he will receive the request. He is still around in here.
https://www.civicforums.com/forums/1...kits-sale.html
wonderz
Oct 20, 2004 10:28 PM
