polyfill
Old Mar 14, 2005
jttegx's Avatar
OMNES AD UNUM
polyfill
http://www.crutchfield.com/S-jrTo0Ta...41&search=poly
anyone here used polyfill before? pros, cons? looks like cotton you can find in blankets or pillows
good investment for ported enclosures or is it pointless since theres a port which affects its purpose?
Old Mar 14, 2005
LiKEaFeRiO's Avatar
I believe its supposed to be polyester filling, not cotton.
You can go to a $.99 store and buy cheap polyester filled pillows and it will do the same thing.
Its supposed to make fake your subs into thinking its in a larger box than it actually is.
Not sure how it will affect a ported enclosure.
I'm guessing a ported box is also tuned so poly-fill will throw it off.
Old Mar 14, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I always reccomend calling the tech support of the company of the sub you bought. I have ran into some companys say yes and some say no. Some say it helps smooth the sound of your sub, and some say it make it worse but that all comes from the manufactoror techs not me.
Old Mar 15, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
everyone has their own opinions, but i've been installing for about 5 years now, and i've had systems ranging from some Rockford Fosgate 6.5" subs in a sealed box to 4 S15L7s in a 33 cubic foot box...i use polyfil in my sealed boxes, but i've never really noticed a difference with the ported boxes (sounds the same with or without, if you ask me)...
Old Mar 15, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Polyfill is used to sort-of trick a box into thinking it's a little larger. It can smooth the freq response slightly (By no means drastic) and offer a slight bit more in the lower frequency extension. It can make a small improvement, I've noticed some in undersized boxes. I have never noticed a difference in either boxes built the right size, or when less than 100% fill is used. (100% fill = 1lb of polyfill for every cubic foot of enclosure volume.)
A good example of polyfill working is when my friend pulled his Boston Accoustic 10" sub out of an enclosure and wanted to replace it with, if I remember correctly, an Eclipse sub. The eclipse wanted 1cu. The box was .75cu for the Boston. We stuffed it, it sounded pretty good.
Old Mar 15, 2005
skipbarber's Avatar
i stuffed the crap out of my box, and believe everyone when they say it doesnt make a big difference. I mustve stuffed two bags of polyfill in my box before it cleaned up the sound.
Old Mar 15, 2005
playa6tnine's Avatar
playa6tnine is an unknown quantity at this point
how much of that stuff are u supposed to use in order to tell the difference? what if you use to much?
Old Mar 15, 2005
J187's Avatar
Look above. 100% fill = 1lb of polyfill for every 1cu ft of air space.
5peed|2acer
Jul 10, 2006 03:41 PM
iLLuMiNaTi
Oct 29, 2005 02:15 AM
doubledeuce2k2
Nov 5, 2003 01:53 PM
cdmx
Feb 19, 2003 10:40 PM
mohawkboom
Mar 13, 2002 12:47 PM
