sealing material
Old Mar 13, 2005
jttegx's Avatar
OMNES AD UNUM
sealing material
im looking forward to seal the inside of a sub box so it doesnt leak any air at all and sealed tight on all edges. the box is already made, but i just want to make sure theres no air leaks by applying some glue on the edges of each corner inside the sub box. i heard of elmers woodglue but how about "liquid nails adhesive" (specifically for paneling wood & foam molding)?
http://www.liquidnails.com/adhesives/ln-910.html
remember sub box is already made, just want to make sure for air leaks
another question: what size screws would u use for 3/4" MDF wood to mount a sub? would 10 x 1 1/4" be ok or should i do longer?
Old Mar 13, 2005
civic01vtec's Avatar
i used liquid nails on all of my boxes.
Old Mar 13, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
I'm a fan of silicone caulk. Just make sure it is completely dry before you put the sub back in, the fumes as it dries can eat away some of the rubber compounds in the surround of certain subs.
Old Mar 13, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I have used both to seal. Either is fine. Another idea is to seal as you mentioned, then after that dries, spray the whole box interior with a spray noise dampener, such as...
Old Mar 14, 2005
jttegx's Avatar
OMNES AD UNUM
is it ok to put the sub back in like 1 hour after the liquid nail? its a ported box so im guessing that port will just let air in and out?
Old Mar 14, 2005
ehhh.....i usually wait 24 hrs. Look on the tube, it will say how long it takes to cure.
Old Mar 14, 2005
zachgeyer's Avatar
then dyimate over
Old Mar 14, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
If I were wanting to "seal" a box,I'd have sealed it when assembling with a liquid nail type substance, ran a bead in the corners, then used either a spray dampener, or similarsubstance. ou could use rubberized undercoating, spray bedliner, etc.
Old Mar 14, 2005
jttegx's Avatar
OMNES AD UNUM
what does that help? got any links where i can read about spray dampners?
Old Mar 14, 2005
wicked02civic's Avatar
wicked02civic is an unknown quantity at this point
Why are you wanting to seal a ported box? You say you don't want any leaks, and there is a big port in it?
Old Mar 14, 2005
Mystic3030's Avatar
a port is made to certain specifications for a certain frequency. an air leak will disrupt that.
Old Mar 14, 2005
werd
Munzy
21
Oct 7, 2015 07:48 AM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
