Running wire...
Old Mar 12, 2005
MegaHurtz's Avatar
Running wire...
Okay so I am about to purchase a 2 chan amp to put in my car. Currently I run my wire under the sill plate and it's been fine so far, but I am wondering how much wire I can put under there before it gets "full". Right now on the driver side I have 1 stinger expert series RCA (thick as hell), remote turn on wire, and phone wire for amp lowpass control. Passenger side I think has only 4 awg power wire.
Question is: Do I have enough room under my sill plate to on the drivers side run a second stinger expert RCA and speaker wire, and on the passenger side run a speaker wire?
Secondary Question: Where do you guys run your wire as an alternative to under the sill plate?
Old Mar 12, 2005
paradoxblue's Avatar
as for speaker wires.. if u wanna u could pull the centre console. and back seats and runt he thinner wires right up the middle. as if they are layed flat u wont know from the back.
this is what i may do. just for the corntol and speaker wires. so id ont need to worry about the power wires interfieering.
Old Mar 12, 2005
MegaHurtz's Avatar
could do that
will i be able to pull wire thru there without removing the front seats
already got lots of wire in the center console though becuase of the DVD player in there but could always make room
Old Mar 12, 2005
jttegx's Avatar
OMNES AD UNUM
i ran my rcas in the center to keep it away from the power cable. its pretty much from trunk, under rear seat, under rear floor mat, thru passenger left side seat, under passenger floor mat, etc.
not a flush and clean install for profession, but enough to just to the point.
Old Mar 12, 2005
MegaHurtz's Avatar
not under the carpet?
my RCA is on the driver side sill plate, the power wire on the passgner, so they are nowhere near each other
Old Mar 12, 2005
jttegx's Avatar
OMNES AD UNUM
i would've ran it under the carpet, but it was too much work IMO. im not showing my system since i dont have much, just did a simple install just enough so it plays fine and hooked up properly.
Old Mar 12, 2005
MegaHurtz's Avatar
bump
Old Mar 12, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
probably wont fit under there. I have wires under my sill plastic, up the center console, and under the carpet on both sides of the seats.
Old Mar 12, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Mega, I have two sets of relatively thick RCAs running down the driver's side w/ a phone line bass **** wire and speaker wire and still, there is room. Also, you can run some wire under the metal plate and some over it - I can take a picture of what I mean tomorrow if you want, - I'm doing a Civic install.
Old Mar 12, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
that channel under the sill plate can hold alot of cable. My drive side has a 4 guage power cable, and two sets of speaker wire. Passenger side has a 6 channel rca cable, and two sets of speaker wire. Both sides have plenty of room left
Old Mar 12, 2005
MegaHurtz's Avatar
hey since we are on the subject, how do i remove the sill plate completely, on both sides?
tx for the answers guys
Old Mar 12, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Pull really hard and break it, then get a new one from Majestic Honda. Or at least that's how I got mine off.
Old Mar 13, 2005
MegaHurtz's Avatar
yeah I think imma go with the one that DOESNT involve breaking it
Old Mar 13, 2005
J187's Avatar
If you are talking about the middle section that runs the length of the car, then then the front part pulls up with clips, you've just gotta be careful not to break the plastic where the clip goes in. Work at rather than just pull it as hard as you can. The very back of it where it meets the piece that comes down from the inner trim of the quarter panel, you have to take the quarter trim off first, or at least you have to pull the quarter section up from the sill and then pull the middle section out from UNDER the quarter section because the two piece lock together - the quarter section goes ontop of the middle sill section. If this is conusing- I can take a picture in a couple hours just let me know.
Old Mar 13, 2005
MegaHurtz's Avatar
pics are very much appreciated
I am talking about the piece that is at the bottom of the door jamb when u open the door. that is kinda like a step i guess to get in the car
Old Mar 13, 2005
J187's Avatar
You'll notice in the following picture that there is another rectangular hole for a tab, the plate tabs in in the fron as well but on the side rather than the top of the sill.
Old Mar 13, 2005
MegaHurtz's Avatar
ahh okay i thought there were clips like that on the side but didn't want to take my chances, thx
Old Mar 13, 2005
J187's Avatar
No Prob
hokiedad4
May 3, 2015 10:06 PM
dragonsblood
Apr 27, 2015 12:28 PM
Dmitri
123
Oct 13, 2005 08:01 PM
JoeB16
61
Oct 16, 2003 07:58 PM
stpfrancois
Jan 19, 2002 08:53 PM
