indiglo gauges going out?
Old Mar 11, 2005
Caucasian.Asian's Avatar
my indiglo gauges keep on turning on and off. there is no loose wire because when i turned them on (when they were working) i grabbed the harness and shook it and tugged on the wire, nothing happened.
at times i just sit there and they turn off fo rno reason! can these gauges go out? could there be something wrong with the fuse? (the fuse it in there tight with electrical tape holding it so it doesn't slip out) so can it be a bad fuse?
i'm about to buy a new one from ebay...bleh
Old Mar 11, 2005
skipbarber's Avatar
samething happened to me, they started to flicker, then theyd stay off until i went over a bump. turned out the cylindrical fuse holder broke and the fuse wouldn't make contact on it half the time. It was hard to find the culprit, i mustve taken my cluster out like 3 times before i realized that the fuse holder was missing like 2 tabs that "click" it in place.
Old Mar 11, 2005
lol, yeah thats why i used the electrical tape. it broke off like 2 times but so much tape is holding it now its not even funny! idk what the problem is! i think i might just buy a new one off ebay. i'm tired of trying to fixx LITTLE crap that takes forever to fix.
Old Mar 11, 2005
skipbarber's Avatar
i took it out completely and replaced it with a blade-type fuse-fuse holder. solved the problem.
Old Mar 11, 2005
^cool, i'll try that this weekend. kragen should have right?
+rep to you.
Old Mar 11, 2005
skipbarber's Avatar
i dont know what kragen is, but ok
and check your ground while youre at it too, make sure its solid.
Old Mar 11, 2005
skipbarber's Avatar
i dont even remember giving it to you before, lol:
vBulletin Message
You must spread some Reputation around before giving it to Caucasian.Asian again.
Old Mar 18, 2005
the new fuse holder didn't work. that sucks... eBay here i come...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
